Great work! Is the front bumper swap possible without the new headlights? I'm looking to simply swap out the 2014-2016 grille for the 2017+ grille, but it looks quite pricey if you factor in the lights and everything else.
I don't think so because the 14-16 headlights have a different shape. The 17+ headlights have a cleaner look, the bottom is straight.
This might interest you. But this is a full custom bumper swap
Thinking about doing this swap. Going to Japan next month, so might try and source the headlights there.
Did you ever resolve the DRL issues while in auto?
Also the check headlight system message?
Amazing detail there, I know this thread is rather old but since you also did the taillight swap -
I just ordered a set of jdm LED taillights for my 2015 and was wondering if those are simple plug an play or is a separate harness needed there as well?
The outer taillights with the led signals seem to come without any cables - i looked up and found part numbers for harnesses but it looks like most of them are for models with the halogen bulbs?
Did you find out if it was plug and play because I’m pretty sure I saw a different thread that said they are and vice versa
