Tire size for square setup
im planing on ordering some niche verona in 19x9.5 35et all around. i want the all around concave look. Im looking for advice on tire size. i was looking at 245-35-19 all around what would you suggest?
For a 19X9.5 you would be looking at a 265/30/19 or 255/30/19.
A 235/35/19 is basically close to a 245/30/19...which as you can see is clearly undersized.
If you went with the 255/30/19, you might just clear in the rear...maybe some camber arms might be needed.
The front is gonna rub for sure.
A 19X9.5 is a little much for the front. If it was an 18X9.5 you'd stand a better chance.
19x9.5 +38
Had 2 questions though, I know you recommended the 255/30/19 tire, but there's not that many tire selection for that, what other tires would you recommend?
You also said it might rub in the front, even with this tire / wheel set up, would it rub? I'm on RSR down springs btw
Was thinking about going for Verde Axis V99 wheels all around:
19x9.5 +38
19x9.5 +38
As for selection, Tirerack has 19 different tires available in that size from Summer to All Season...and from top tier to low end brands. I can't imagine a wider selection than that.
You could try 265/30/19 also...Tirerack has a selection of 13 different tires in that size. I would avoid Michelins in this size.
After some other fitment tests, the 19x9.5 +38 255/30/19 would be fine for a square setup.
You'll see on Tirerack that you can pretty much get whatever tire you want...aside from Winters in that size.
Not saying you gotta buy from them, it's just a good website to see what's available.
Fitment Industries is a good source of info, but honestly not the best source. They are probably a good starting point to then do further research after.
Tire rack only has 1 all season tire which is the Michelin unless I'm inputting it incorrectly?
https://www.tirerack.com/tires/TireS...earDiameter=17
I didn't realize you were looking for an All-Season tire specifically. For the size I can understand why there aren't many All-season tires available...any reason why you want All-season over Summer tires?
At the end of the day All-Season is just a gimmick anyways...you can't really have a tire that's great in all seasons. If anything you stand a better chance with All-Weather tires...which are different from All-Season tires.
The search result was correct...they are showing 1 All Season tire available...and 18 other variations of Summer performance tires.
If you're going with 19 inch rims, a 40 sidewall is absolutely out...the tire is going to be way too tall for a lowered car...this is taking into account the smallest 40 sidewall 19 inch tire you can get, which is 225/40/19.
