lowering
lowering
so after reading numerous threads ,still can't decide on rsr superdowns or rsr downs ,car is a 2014 is 350 awd ,planning on 20 mm spacers with the drop and keeping stock 18 inch wheels setup so far im leaning towards super downs,. from what ive read the superdowns will be 1.5 r drop roughly all the way around. will it rub ? any suggestions, or experamces will be greatly appreciated. after I painted my calipers and took some photos realized the car has to much wheel gap , expesically in front
Your #1 Lexus Vendor
Down springs, super downs are pretty low of a drop..
Contact us for pricing!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
My 2cents
For what its worth,I had the RSR downs installed 2 years ago. It dropped it around a inch and a half+. I can get one finger in the rear an two in the front, as far as wheel gap. [Im sure theirs a joke there] I still have to be careful around railroad tracks an such, any lower an it would be tough sledding for me. But i live in Colorado and the roads are crap, so your results may vary. My set up: 2014 IS350 AWD, 18'' Niche wheels on pilot super sports [summer] Factory F-sport wheels on pilot alpines [winter] as well as SPC camber arms to get it closer to spec. I run a little camber and get slight rubbing when my trunk is loaded up and hit big dips. The RSR springs work great and added a bit more sportiness to the car, not to mention I've had Zero issues in 70k plus miles. Good luck on whatever you choose
I’ve had RSR Down Springs on for about 1,000 miles and love them I’ve had no issues.
Meraki Autoworks (09-09-18)
Took some measurements from ground up to top of the wheel well. F/L 25-1/4, F/R 25-9/16, R/L 24-3/4, R/R 25. Defiantly not truly squared up, but it was off with the old springs. I had it checked out at the Lexus dealership, was told it was within specs. I've checked several vehicles over the years and they all seem a little off. My wife's BMW is off as well and the suspension is bone stock. Seems brand wide and could only be rectified by adding coilovers, but even then once you load it up in spots it'll sit different.
