Roav C1 Dash Cam Install - Suggestions/help!
Old Jul 21, 2018 | 08:20 PM
Emotionr's Avatar
Emotionr
Question Roav C1 Dash Cam Install - Suggestions/help!
Has anyone installed a Dash Cam in their IS250 2014?
I just got a Roav C1 Pro Dash cam and was wondering if anyone installed it/hardwired or wired in?
I am trying to decide where to put it, while allowing the cable to reach the USB ports - under the arm rest console.
It came with a cig -> USB adapter too, but... that is even further to reach.
Any suggestions on installing a dash cam to make it seamless while reaching the ports inside the arm rest?
Thanks!
Old Jul 22, 2018 | 08:00 AM
Sasnuke's Avatar
Sasnuke
Thanks!
You can hardwire it into the rearview mirror. This will save time running wires everywhere in the car.
https://www.clublexus.com/forums/is-...etector-7.html
Old Jul 22, 2018 | 06:40 PM
Emotionr's Avatar
Emotionr
That link shows for a radar dedector.
I have a RoAV C1 Pro Dash Cam, and it uses a USB (Male Micro 5-pin) cable that goes into a USB cigarette lighter adapter.
How would I go about connecting a USB to to the rear view mirror? I like to do this for obvious reasons:
1) Cleaner
2) I can find a short USB cable and not have to use the long one that came with, and install the cables/hide.
Thank you
Old Jul 22, 2018 | 07:07 PM
Sasnuke's Avatar
Sasnuke
1) Cleaner
Thank you
Whether it's a dash cam or radar detector, or anything else, the principle is the same, you need Power, Ground, and IGN.
There is another thread where they wired a USB port to the mirror wires. Or you can get a cable the plugs into the dash cam and has wires to install into the mirror wiring.
A search of Amazon should find everything you need.
Old Jul 22, 2018 | 07:25 PM
Sasnuke's Avatar
Sasnuke
Try this link: https://www.clublexus.com/forums/is-...diy-guide.html
Old Jul 23, 2018 | 01:22 PM
dojoman's Avatar
dojoman
Remember you need DC-DC converter if you're going to tap power from rearview mirror for your dash cam. People are saying it's the same thing but depends on how you translate it, average Joe might think it's just plug and play. You'd need 12v -> 5v converter.
Old Jul 23, 2018 | 01:43 PM
Sasnuke's Avatar
Sasnuke
Originally Posted by Sasnuke
The link in the last massage does cover if it is that the dash cam uses a 5V source, rather than 12V. The DIY'er had an adjustable unit to vary the voltage output.
Old Jul 23, 2018 | 02:51 PM
Edwin8484's Avatar
Edwin8484
You will need either the direct wire connection from the camera to the car. Usually the manufacture of the camera would make this available. Or get an adapter that allows you to plug in the cigaret connector to it. One of the best one for dash cam is called Power magic pro. See if it would be compatible with your camera. This should allow you to record while park if the tour dash cam has the feature. Be careful that you put the settings on the power magic pro so that you don’t kill your battery.
Power Magic Pro BlackVue Vehicle Battery Discharge Prevention for Parking Mode for BlackVue DR500GW, DR550GW, DR650GW, DR650S https://www.amazon.com/dp/B008B8ERIO/ref=cm_sw_r_cp_api_J0KvBbHV0QDKP
Old Jul 23, 2018 | 03:30 PM
tofuprod's Avatar
tofuprod
I wired the current dash cam we have in the IS through the A pillar and have it tapped into the fuses with a quick disconnect along with a safety fuse
Old Jul 24, 2018 | 03:05 PM
E46CT's Avatar
E46CT
I powered mine using wires from the two wire bundles located above the map light panel piece. Use a multimeter to identify the switched 12v and ground. Then you step down using a 12VDC to 5VDC converter and tuck everything up inside that panel.
Old Jul 24, 2018 | 03:34 PM
MX73's Avatar
MX73
I have the same camera. I went down the a-pillar, under, the glovebox, under the center console and up a small panel in the armrest. The cable is long enough to reach.
I didn't remove the center console. I just tuck the wire inside the center console running down the side. It's tight enough to hold the wire in place. I did use the dual usb cig adapter.
Old Jul 24, 2018 | 04:10 PM
E46CT's Avatar
E46CT
Careful around A - pillar. not only do you want to be careful about where you put that wire, you also don't want any static discharge around the airbag. It can be done, just a tad risky.
Old Jul 25, 2018 | 08:31 AM
Emotionr's Avatar
Emotionr
Question
I am considering a fuse tap.
However, to clarify - does this mean, I have to splice or cut the usb end and connect it to fuse connector - then plug it to the fuse box on the bottom left of the steering column?
Does this remove the fact - of connecting it to a power source like the cigarette lighter or USB ports (hidden in the arm rest)?
Do you have pictures to show?
Old Jul 25, 2018 | 08:34 AM
Emotionr's Avatar
Emotionr
Question
The ROAV C1 Pro?
Do you have pics of what you're saying? I thought about that, but was concerned about the OOB power/wires would be long enough. How did get it into the arm rest area without the wires just showing? Got pics of your wiring from top center to arm rest?
Thanks
Old Jul 25, 2018 | 02:36 PM
MX73's Avatar
MX73
I don't have the pro but it's the same style in 1080p, the original C1. The supplied cable is 9.8' long. Plenty long with some slack. I'll get some pixs tonight.
