Roav C1 dash cam. I tuck the wire underneath the headliner. You don't have to remove, just shove it between the windshield and the headliner.
The route I went. Headliner, a-piller (popped it off and ran the cable behind the side curtain airbag. It should not interfere with the deployment)
Remove weatherstrip and the small black plastic trim piece. Tuck wire behind the plastic trim piece. Reinstall trim piece and weatherstrip.
Remove bottom panel of the glovebox and run the wire through. Install the bottom panel. Run wire behind center console trim piece (from glove box to armrest.)
Open armrest, pop cover panel, fish usb cable from center console into the opening. Put cover back on. If done right, you shouldn't have any exposed wires anywhere but the cam to the headliner.
