Drive Mode - Temporary Shift Range
FWLIW the 2IS has a variant on this. If you paddle down to say 3rd gear it won't exceed 3rd until you paddle up or come to a complete stop.
Once stopped it reverts to 1st through 6th use.
Did they do this to the 3IS?
A quick press of the Trac button and it disables Trac until the vehicle hits and sustains 40mph for few seconds (IIRC) and then enables Trac. This can be defeated by holding trac for 5+ seconds while stopped. It remains disabled until key off, you wreck (all nannies off), or press the button again .
I'm gonna try that full-off for the TC today! There are times I'd like to have it remain off at 2nd gear without having to stop again if course.
I believe it was November 2013 when production changed and cars started to be able to bounce off the limiter when in manual mode. It says it will in the owners manual however, another thread determined cars produced before 11/2013 (I think) would not bounce off the limiter and instead shift up even in manual.
My 2IS has a 2012-11 production date and bounces off the limiter until shifted manually.
If you were tracking the 3IS the auto shift thing could be a huge bummer if corner entry speed happened to be near redline and it shifted right then and you loose engine braking...
Received 1,732 Likes
That's interesting....
Yup it would be a bit of a bummer. A few times a week I drive the car pretty dang hard and it's not a great loss but on occasion I do have to pop it down a gear after I did not intend for an up shift. With the 8 speed trans 2-4th gear is where I spend most of my time when pushing the car so again it doesn't bug me much as I can flip through these pretty quick.
BTW that turning trac all the way off (new to me) allowed the car to shift at the 7.2k rpm point instead of 6.9 where it usually would. Awesome. Thanks!
drives cars
Yup as Sansuke said just the first few months of production for the 3IS. Mine was built 07/2013.
Yeah for some reason, in D drive, it'll shift at 6200-6300 or so even if floored (with the stock limit of 6600 RPM). It's very silly. In M, it'll hold it to redline but auto-shift. I don't have a tuned car so I am not sure how it works there, but seems like it's similar in that it shifts about 300 RPM before the limiter.
It will shift at the 6600 limit with TC off and manual mode, regularly so far. Manual mode TC on about 6300. Drive mode TC on it will be as low as 6100 depending on what mood the car is in.
Just burned through the quickest last quarter tank in a long time playing around with this
However, if you put the car in D4 (using paddle shifters while the shift lever is in the D position) than the car will shift normally through gears 1-4, but not exceed 4th. You've then set your "shift range" to gears 1-4.
That is how I understand it is "supposed" to work. .
Right. Activating "M" mode while in D, by using the paddles, is merely a temporary override allowing you to shift up or down. The car will resume normal "D" mode after a few seconds.
drives cars
I tested it out this morning. The D mode in Normal and Sport shifts at ~6200 rpms. The Manual mode with Sport setting, trac on, it auto shifts around ~6500 rpms. There is pretty good pull on the remaining 300-400 rpms left so its good to know that if you really want to pull hard to redline, shift that lever to the left. One question...is there a difference in redline shifts between Manual mode and Normal and Manual mode and Sport? there shouldn't be but just wanted to know if you knew.
I tested in normal mode with M mode and it shifted around ~6500 rpm. If i leave in D, it shifts around 6200 rpm. There is a noticeable difference between the shift points between the two modes. If i turn off trac, it just bounces off the rev-limiter
drives cars
I think he was asking about the auto-upshift quality at redline as compared to the shifts in D drive, of which I can tell no difference. Obviously it shifts earlier in D as has been previously posted. But, the speed/feel of the shifts seems to be the same to me.
Anyone use this mode?
While in drive mode, we're able to select a top / maximum gear the car will shift into, temporarily. Do this by using
the paddle shifters and selecting a gear 2-8 (2-6 on six speed).
Nice for downshifts when I dont want to be in manual mode. However, would be even nicer if it worked as it seems it's supposed to. When in traffic, I dont need the car shifting up to 5th gear at 25mph, but rather would like to limit this to say 3rd gear as I know I'm about to slow back to 5mph.
However, the problem is the after pushing the accelerator for 4 seconds it comes out of this mode, rendering it useless for my purposes. I guess it's the "temporary" part that's got me baffled
Anyone use this and find a good purpose for it?
is this on every model including is200t?
