2017 IS - need power source.
Old Apr 23, 2017 | 03:11 PM
is200turbo's Avatar
is200turbo
Default 2017 IS - need power source.
Just brought a 2017 is200t f-sport. I'm trying to install a dash cam. Is there any power outlet besides the two USB plugs in the center console? My dash cam has a cig lighter adapter and I can't find any cig lighter outlet in this car.
Old Apr 23, 2017 | 03:54 PM
isosunrise's Avatar
isosunrise
In the glove box I believe or in the center console. You could hard wire to mirror I believe.
Old Apr 23, 2017 | 04:39 PM
Solara350's Avatar
Solara350
you can't . You either buy an adapter for USB port or buy a new dashcam comes with USB
Old Apr 23, 2017 | 05:21 PM
is200turbo's Avatar
is200turbo
thanks for the info. i found the 12v outlet inside the center console but looks like its going to be difficult to run wires.
I removed the passenger lower dash cover and found an open connector in the kick well area. I dont have my multimeter right now so can not check for voltage so just wanted to see
if anyone knows what that connector is for.
Old Apr 23, 2017 | 05:57 PM
Sasnuke's Avatar
Sasnuke
Originally Posted by PatrixUSA
The power outlet is in the center console. Page 422 in online manual:
http://drivers.lexus.com/t3Portal/do...f/OM53D76U.pdf
Instead of running the wire down to the console, some have wired their dash cams directly to the rear view mirror, as it has a power supply.
I believe this thread shows how to tap into the rear view mirror's power:
https://www.clublexus.com/forums/is-...diy-guide.html
Searching the 3rd gen thread may offer more results. Happy driving.
^^ +1...Just hardwire it to the mirror connector...it's literally right there. I think the thread above shows you how to install a USB port/connector if I'm not mistaken, but others have just tapped the dashcam power and ground onto the mirror power and ground directly.
Old Apr 23, 2017 | 06:06 PM
is200turbo's Avatar
is200turbo
is my mirror the same? not sure how to take off the cover.
Old Apr 23, 2017 | 07:19 PM
Answer's Avatar
Answer
Go directly in the fuse box with some low profile mini add-a-fuse.
Old Apr 23, 2017 | 07:55 PM
is200turbo's Avatar
is200turbo
nvm, i figured it out. cover slides down. I'll attempt to tap into mirror connector. Is the wiring the same for the 2017 IS? If not anyone have the correct wiring diagram?
Old Apr 23, 2017 | 08:37 PM
LexusKJ's Avatar
LexusKJ
I literally just did this today, I hardwired it to the fuse box. I thought about tapping into the mirror but I already had the hardwire kit so didn't want to waste it, and like you I wasn't sure if anything changed for 2017 with the wiring for the mirror.
Old Apr 23, 2017 | 10:08 PM
Sasnuke's Avatar
Sasnuke
The mirror looks to be wired the same from 2014 to 2017...here is a pic I posted for another member looking to hardwire a dash cam...or was it radar detector...doesn't matter, there's and Ignition wire and a Ground wire.
Old Apr 25, 2017 | 04:12 AM
is200turbo's Avatar
is200turbo
Thumbs up
Thanks for the info. I will hopefully finish the install this weekend.
Old Apr 25, 2017 | 08:01 AM
350phi's Avatar
350phi
I'm running VIFO A119 dash cam with 10ft USB cable with a right angle mini usb connector. I ran the cable above the roof liner and down the passenger A pillar. Ran the cable behind the glove box and down the side of the center console. I removed the center console arm trim (where the joystick is at) to pull the cable through and removed the center console box and notched a corner of it to expose the usb cable. I used a low profile belkin two port usb cig adapter and connected my dash cam. I have the other usb port to my phone's lightning cable for phone. I personally don't use the car's usb to charge (charge too slow) or connect my phone. Only reason I did all this is so I can unplug the power to the dash cam on demand and have a usb connection for a laptop when ever I need to pull video. Not all laptops have micro sd card reader so it's easier to find a laptop with USB. Maybe this can help you guys. I'll try to get pictures later.
BTW, there is a 12v cig port in your center glove box, look harder
Old Apr 25, 2017 | 11:03 AM
Machine13's Avatar
Machine13
is200turbo, what brand and model dashcam did you get? Just curious. This is something I eventually want to do, too. Maybe in the front and back. Thanks,
Old Apr 25, 2017 | 04:53 PM
is200turbo's Avatar
is200turbo
i brought a garmin dash cam 35. I have some eBay dash cams for my civic that work ok but decided to buy a better one for my IS.
jklangen99
Apr 13, 2016 02:39 PM
Eolafan
Dec 28, 2015 02:11 PM
jmoney6
Nov 24, 2015 03:15 PM
crazy_vag
Jun 17, 2009 11:21 PM
wayner
Mar 10, 2006 07:21 PM
