Winjet F Sport foglights
#62
What I did was to use fine grit (320 I had on hand) sand paper and smooth out the edge around the shrouds. My intention was to reduce the sharp edge when install/remove the shroud would reduce change of scratching the surrounding. I guess that also help the shroud sits better and less gap.
#65
https://www.clublexus.com/forums/is-...ights-diy.html
I did the install with the button inside the cabin. The hardest parts for me were removing the covers where the foglight went, and running the control cable through the firewall.
I taped the fuse and relay together, then mounted them to the side of something by the battery using velcro, and with the red wire from the fuse, i went straight to the battery., afterwards I routed the wires to the passenger side headlight, steered the wheel all the way left, exposed the back panel, and dropped the foglight connector for that side towards the wheels and fished for it with my hand, then i ran the wires above the radiator and then did the same for the drivers side. The drivers side was more difficult since there was the fluid reservoir kinda in the way so I wound up breaking a tab when removing the cover on the drivers side. You're going to want a stubby phillips, and a not stubby phillips, a flat head, small 10mm wrench or socket with extension, and a tiny flathead, zipties, electrical tape and a lighter, maybe crimpers and crimp connectors. I think I got a long hex screw driver and just put the tip of the cable onto the screwdriver and shoved it in through the firewall. I already have a dashcam hardwired to the fusebox, so i wound up tapping the ignition wire from the foglights harness to the dashcam fusetap.
https://www.clublexus.com/forums/is-...tallation.html
This install took me about 5-6 hours, and the only other work I've done to the car is hardwiring a dash camera with the above link as guidance. It's not hard, just tedious and a little time consuming. I found that you have to trip the corners on the bulb housings, where a bolt goes through because i was having some fitment problems. i only had to cut the plastic surrounding it, but it didnt compromise where the bolt went through, I also couldn't thread it via the bottom mount. that little hole in the housing cap i assumed was meant for adjusting the foglights don't work because there is metal in the way, so i ziptied it.
#67
In the pictures attached, the red rings is where you wanna look at for fitment, I'm too lazy to rip them out of my car, but in the other picture, the green triangles are where i cut. I think it's just the top triangle you gotta cut, but i might have done both because i'm pretty bad at remembering things.
#68
Installed them today. Fitment is MUCH better than the Spyder ones. Very one small and minor gap. The adjustment hole is very handy, just stick in a Phillips and adjust it any way you want.
You're paying $140 for the covers, wiring, and housing really since the light bulbs are changeable which was a HUGE PLUS for me.
The h11 bulbs that came with it is 4300k so theyre daytime lights - yellowish. Will be getting 6000k ones soon.
Attachment 406018Attachment 406016Attachment 406017
#69
I had mine for a month and they look great imo also fitment is on point. I should've painted the housing gloss black before getting them installed. I'll be getting 6000k LEDs this week, the 5000ks are too dim...
#71
Yeah mb... I forgot to mention I wanted a whiter light to match the DRLs a bit better and the 5000ks are halogen bulbs. I can't seem to find the exact amount of lumens these bulbs have. Any recommendations on bulbs that match the DRLs the best?
#72
Philips X-tremeVision LED Fog Light, Fits Fog H8, H11, H16, 2 Pack
#73
I just ordered these, i'll post pics when I get them installed
https://www.amazon.com/gp/product/B00U2NHLTI/
#74
Those are some expensive and interesting bulbs :O I have the Philips H11 Diamond Vision Halogen Headlamps on my fogs atm.
#75
Does anyone have any close up pictures of the electrical connector for the Winjet fog light assemblies? My 2014 car is pre-wired for fog lights and I would like to use the existing OEM fog light electrical connectors (and add the OEM stalk w/ fog light switch). To my understanding, the DT Moto/Spyder fog light assemblies are an exact replica mold of the actual JDM fog light assemblies and are plug and play if your car is pre-wired. The iJDMtoy kit has different connectors and will NOT be plug and play. Any input or close up pictures of the Winjet electrical connector?
Here is a picture of the OEM fog light connector, in my bumper, w/ a "dead" plug from the factory because it is unused:
Here is a picture of the OEM fog light electrical connector (car side) with the "dead" plug removed:
Here is a picture of the OEM fog light electrical connector (car side) next to the DT Moto/Spyder fog light assembly electrical connector, which shows fitment for plug and play if your car is pre-wired (plus the addition of an OEM stalk w/ fog light switch for control):
