Might Need New Brakes Soon
my 2015 is350 f sport has 20k miles on it, so the dealership said they are recommending me to replace my front brakes soon. Havent seen the price they are quoting my, but j/w if i dont go with the dealership brakes, what brakes, and from where, should i go with??
You should do a search in the Brake forum for more advice.
Dealer wanted $670 to replace my front rotors and pads at 20-22k. I did it myself quickly for about $200 on parts using Stop Tech/Centric High Carbon Premium Rotors ($75+ each) and Akebono ACT pads ($50+). It's easy and you'll love the non-dusting of the aftermarket pads. |
Unless the steering wheel shakes when you brake, just change the pads out for under 100 bucks. get the ceramic pads too...
That's weird, my dealer quoted me under 200...
I'm going with Akebonos soon. |
Hi guys! I'm new to the forum. Can the IS200T use the same brake pads for the IS350? I'm looking at the Akebono ACT 1118 right now but I'm not sure if it will fit for my car.
Originally Posted by pandatroop
(Post 9597153)
2016_lexus_is-200t_sedan_base_w_oem_1_717.jpg |
Originally Posted by flexspace
(Post 9597129)
Originally Posted by Vivid101
(Post 9597090)
Originally Posted by RocketG35
(Post 9597198)
For a front rotor and pad replacement? Or just replacing the pads? If it's a full, that's a heck of a deal and I'd go for it. If it's the pads only w/o resurface - it's way overpriced (and expected of dealers) for a few minutes of work and $50 parts. I believe they don't recommend resurfacing rotors, but if its in spec, why not?
20k miles?!
Ive got 45k miles on mine and have about 7mm left on the pads. What are you doing to need new brakes after 20k miles? Tracking? |
Originally Posted by Mrg02d
20k miles?!
Originally Posted by EZZ
(Post 9598833)
Do you have an F Sport? My F sports survived to 20k
Have you guys changed the fluid? Factor recommends at 30k or 3 years
Originally Posted by Jbreezie
(Post 9599682)
Rather than believing everyyhing the dealer recommends, why don't you inspect the front pads yourself to make sure? If there is plenty of thickness left you don't need to replace them. I doubt you will need new pads st 20k unless you drive it hard.
