Replacing Back Up Light with LED Bulb
12-17-15, 12:47 PM
Can anyone tell me how to easily remove the old one to install new bulb?
12-17-15, 04:10 PM
Quote:
Originally Posted by
tx_is300
Really easy. There are tutorials on youtube.
12-17-15, 06:28 PM
tx_is300
It is straight forward provided you have a right tool in removing the plastic plugs.
I used this -- it won't scratch the surrounding area and yet provide enough strength to pull the plugs out.
12-17-15, 07:22 PM
Pop off two clips each side and it's right there.
12-17-15, 07:26 PM
AndyL
What's the name of this screw driver?
12-17-15, 08:14 PM
istech
It's called a Plastic Fastener Remover or a Door Panel Removal Tool.
12-17-15, 08:19 PM
tx_is300
Installation is fairly simple, you could always refer back to your owners manual if you don't know. If you want to save some money, you could also use a flathead head screwdriver or a hammer, but that tool makes the job much easier. Hope this helps!
12-18-15, 04:15 AM
I recommend a good quality bulb, I changed mine out to an average LED off of amazon and it's not nearly as bright as OEM, looks much better but not great for visibility at night
12-18-15, 06:44 AM
Thanks to all for the feedback! I did it last night and was easy but would been easier with the suggested tool. I used a Swiss Army knife so that will work also.
12-20-15, 03:56 PM
What bulb can be purchased that is brighter than OEM? I find the OEM bulb not bright enough.
12-20-15, 05:29 PM
i never expected the reverse light to be used to improve rearwards visibility.
you should try the Philips LED 5W, 921 size.
One word review: AMAZING.
12-24-15, 01:52 PM
AndyL
Crap. Sorry for the late response. I just used pliers to take out the plastic screws.
LaTrelle
RX - 1st Gen (1999-2003)
11-02-18 08:54 PM
Black16
GX - 2nd Gen (2010-2023)
07-25-17 05:12 PM
peterbird
08-24-16 04:43 AM
KYLESTONES
09-25-15 07:57 PM
mann777
GX - 1st Gen (2004-2009)
04-16-11 11:57 AM
