use flathead screwdriver and stick it under the glass to pry it out. After that you'll see your bulb attached to a plastic white piece. I think you have to take apart the plastic part (it splits in 2, it was kind of tricky because I was afraid of taking it apart). But once you get that over with, putting in your new bulb and putting it back is a piece of cake.
Once you unplug cable and remove the assembly. look for a small horizontal latch, gently lift with a small screwdriver and slide out the base from the clear housing, change bulb.
