Paddle vs Mannual shift
Does anyone manual shif?. Every video and you tube track test I've seen paddle shifts - I've never seen manual mode used - ever. I love the idea, but is it impractical? Not authentic enough?
The paddles can be used in D mode and M mode. They do the same thing as physically moving the gear shifter when in M mode. In D mode they can be used to temp downshift or upshift but auto mode resumes shortly after. What you are seeing in videos is people using the paddle shifters most likely in M mode.
Yeah
Do you think most people don't use it because it's not authentic enough, or is it that the paddle is just more convenient? I haven't had a chance to test drive because of bad weather.
Honestly its drivers preference. There is no right answer.
On older cars or even my 2IS I prefer the manual mode (S) over the paddles because the paddles are slower to respond than the actual shifter
Perfect for engine braking, mountainous terrain
It's not that it's not authentic. It's a semi-automatic car after all. Paddle-shifter gives me the F1 racing mentality, since I'm a fan. It's more readily available to you to shift without really taking your hands off the wheel. Less hands on the wheel means less control and vice versa.
Also to add that in D mode, it doesn't upshift all the time. I think it depends on what mode you're in (eco/norm/sport/+)
The only reason I never use the stick/manual mode : it's inverted. Look at this post and all the videos.
After 0-60 street cars don't shift all that often unless you're on a track. In a plane, an emergency manuver is to pull back on the stick to pull up, a natural body reaction vs. push forward. In a downshift, it's most similar to a 3/2 H-pattern downshift, i.e. pull back. When autosticks first appeared, Everyone but BMW was pull back = down. Now you've got half one way or the other. Plus non-autosticks have always been pull back to drop to 2 & 1 since the beginning. So pull back to downshift has been engineered that way for every Joe Average to react to in any situation, like it or not.
I refuse to use the shifter until they fix the orientation for gear changes.
Up should not be gear up.
Down should not be gear down.
Only a couple manufacturers get this right these days (BMW and Mazda).
On the other hand, at least the stick is always in the same place. When turning, the paddles are turned and not accessible.
I agree on a street 90 degree turn, but on the track, there shouldn't be too much turn angles that you'd have a hard time up shifting. For the majority of the turns on a track, you down shift right before turn entry and then shift up after exiting the turn.
Sexis350
Jun 18, 2015 03:58 AM
NikonGuy
Oct 15, 2014 02:50 PM
