Aftermarket Wheel Showcase - 3ISx Exclusive
#1666
Former Sponsor
Artisan Spirits and AIMGAIN demo cars run 20s and they look fine. Pretty sure they use a 30 ratio tire sidewall
I have also seen 20s on the rubber band sidewalls and I'm not a fan of the look or the function.
Artisan Spirits
Artisan Spirits
#1667
wheels and offset
could I please get some advice/tips im wanting to buy 19 in wheels for my 2014 luxes is 350 that have a positive offset of 25 the wheels specs are 19*9.5 and 19*8.5 with a positive offset of 25. Would I have any issues going that low on the offset? my vehicle is 2014 Lexus IS 350 base model
#1668
Received 1,732 Likes
I have to say I'm curious as to what kind of vehicle they came off of.
To address your question, if you had stock suspension, you could get away with the 19x8.5 +25 on the front. It would possibly stick out a little, but would probably function ok.
The rear you would have definite issues and it would look odd as well.
#1670
Rohana RC7
Front: 19x8.5 +35 245/35 Sumitomo HTR ZIII
Rear: 19x9.5 +40 265/30 Sumitomo HTR ZIII
Just barely clears in the rear, but rubs in the front on light/moderate compression. Going to need to roll/pull the front fenders. In hindsight, I really should have just went with 225 in the front.
#1671
Rohana RC7
You could likely put a 235 on there and be fine too. Maybe look for one with a narrow tread width...unless you're getting a matching Sumi.
#1672
I'd rather spend the money on keeping the 245 and rolling the fenders as I'm not a fan of how stretched the 225 looks on a 8.5" wheel. If rolling the fenders gets these to fit, I'll take it.
#1673
Just to clarify, the rims are staggered (19x8.5 and 19x9.5), but they have the same offset? Which is +25?
#1674
The HTR Z only had 225 and 245 as an option, and I rolled the dice on the 245 fitting. Craps.
#1675
#1676
Fingers crossed that it'll be enough. By the looks of it, I just need an extra 2-3mm. Rolling and relocating the tabs should be enough, but if not, I'll see about pulling the fender a bit as well. I'll definitely update once its done.
#1677
Hi everyone! Would a square setup 18x8.5 +35 work without any clearance issues with the front F Sport calipers?
Looking to get a set of these Superspeed wheels:
https://www.super-speed.ca/flowform-rf05rr
#1678
However rim design, specifically on the front, will ultimately determine if it clears the big calipers.
The rear won't be an issue at all.
#1679
#1680
Rohana RC7
