Hardwiring a radar detector
Old 05-12-17, 11:22 AM
  #91
EJ255t
EJ255t's Avatar
i have mine hardwired into the rear mirror. Super easy.
Old 06-12-17, 09:42 AM
  #92
PGARazor
PGARazor's Avatar
Originally Posted by matttev
Okay guys. I got it.
For those that have a 2017 IS 200t F Sport. For reference I'm using an Escort iX with MirrorTap
Pull the lower plastic cover downwards. The top part should follow. Now both halves should detach from each other VERY easily. Then you should be able to remove it completely.
Theres 2 cables. Use the one on the right (the one that goes directly to the mirror).
Take your mirrortap and find the second smallest wire adapters. They should go in easily and come out with slight resistance. Black to blue and red to pink. That's it!
Underneath the plastic cover
With mirrortap installed
Use the cable on the right
The mount the iX comes with is VERY strong
Thank you very helpful.
Here is a picture of how it turned out. One thing i did have to do is super glue the mesh to connector, after first time i unplugged dectotor it pull out of clip.
Old 06-14-17, 09:48 AM
  #93
Turismo
Turismo's Avatar
Which size taps are the ones we need to use?
Old 06-16-17, 02:56 PM
  #94
itsx
itsx's Avatar
Depending on which route you go. I have a dashcamera hardwired to the fusebox, and i used fuse taps, i tape my cover over the top of the fuse box now because it won't close properly
Fuse Taps
Amazon Amazon
I bought this mirror tap for my uniden drf7 which uses 2 the middle two prongs from a rj45 (phone line/corded phone jack)
Mirror Tap w/ rj45 style connector
Amazon Amazon
Attached Thumbnails Hardwiring a radar detector-20170407_144630.jpg   Hardwiring a radar detector-20170407_150508.jpg   Hardwiring a radar detector-20170407_150714.jpg
Old 06-18-17, 03:30 PM
  #95
PGARazor
PGARazor's Avatar
Anyone using the Escort IX, and having trouble with it not magnet not holding during a corner faster than 20MPH? i might be missing something other than turning a corner at 20MPH.
Nevermniond i fixed issue, mount was not even. Works perfectly now..lol
Old 10-11-17, 07:13 PM
  #96
TMar66
TMar66's Avatar
Default Sensor cover removal
The instructions are spot on but I have an issue removing the two piece cover as described, the lower half is easy to disengage but I cant seem to separate the smaller top piece. I cant see how it attaches and I don't want to break it, any suggestions?
Old 10-11-17, 07:20 PM
  #97
TMar66
TMar66's Avatar
Default Sensor cover remaval Issue
Old 10-11-17, 11:51 PM
  #98
matttev
matttev's Avatar
Default It may take some fidgeting but it'll go
It may take some fidgeting but it'll go. But yeah definitely don't force it hard
Old 10-12-17, 04:55 AM
  #99
davyjordi
davyjordi's Avatar
Originally Posted by J3ffrey
Just fyi, on my USA 2016 with auto dimming mirrors and homelink it is opposite of this picture, thank you for the guide though, was much easier just reversing the wires rather than having to figure out which is which!
Now the only problem I think is going to be radar assist cruise control and pre collision, figured I'd try it anyway, using a 9500ix.
so, i'm stuck here but with a falcon dash cam. the dash cam wires are red and purple and i've tried to tap into the mirror's blue and purple in both configurations. any help anyone?
edit: i'm using those little clip things that tap into both wires simultaneously ideally making a connection.
Old 10-12-17, 06:13 AM
  #100
GibbsLexus
GibbsLexus's Avatar
Default Hardwire into a accessory fuse
Hardwire in a accessory fuse (ex. cigarette lighter) and ground the black behind the bottom panel.
Old 10-12-17, 08:55 AM
  #101
ZISF
ZISF's Avatar
Originally Posted by atomic350
If you're looking for Leo. This is my setup and it works perfect LOL
Untitled by mrgxxer, on Flickr
Please explain how you got WAZE on your nav
Old 03-03-18, 01:38 AM
  #102
zhifan1
zhifan1's Avatar
Can i assume that the wire tapping is the same for 2016 IS200t base model?
Old 03-03-18, 06:16 AM
  #103
Sasnuke
Sasnuke's Avatar
Received 1,732 Likes on 1,368 Posts
The pin locations are the same for all 3IS...however, between the years and models the wire colors may vary.
Example...if Pin #1 is Battery 12V, then it will be that on every 3IS, regardless if the wire is Pink, or Gray, or Blue, etc.
zhifan1 (03-03-18)
Old 07-22-18, 06:39 PM
  #104
Emotionr
Emotionr's Avatar
I have a RoAV C1 Pro Dash Cam, it uses a USB (Male Micro 5-pin) cable that goes into a USB cigarette lighter adapter.
How would I go about connecting a USB to to the rear view mirror? I like to do this for obvious reasons:
1) Cleaner
2) I can find a short USB cable and not have to use the long one that came with, and install the cables/hide.
Thanks
socaligs
02-01-17 10:31 PM
ahde
05-18-16 07:34 PM
dustin2413
HS 250h Model (2010-2012)
02-07-15 01:32 PM
LexusTexas
04-27-08 01:57 PM
carlos
11-06-07 11:09 AM
Quick Reply: Hardwiring a radar detector
