Just got my car lowered - scraping?
Old Aug 18, 2014 | 09:46 PM
SCSurf's Avatar
SCSurf
Thanks for the suggestions all. I'll use the duct tape approach for now haha. I'm getting the 19s put on sooner than later, so hopefully that extra inch will give it more clearance.
Old Aug 18, 2014 | 10:00 PM
TheShaddix's Avatar
TheShaddix
Just fyi... Going bigger in diameter does not give you an extra inch. It simply changes the rim size, the tire gets smaller in sidewall height.
Old Aug 18, 2014 | 10:09 PM
SCSurf's Avatar
SCSurf
Oh wow. I didn't know that. So the increase in wheel size will not alter height at all? This won't solve the problem then?
Old Aug 18, 2014 | 10:20 PM
SCSurf's Avatar
SCSurf
May have found a solution to my problem!
http://www.ebay.com/itm/9-5-ft-EZ-LIP-FRONT-BUMPER-SPOILER-CHIN-SPLITTER-VALANCE-BODY-KIT-AIR-WING-TRIM-/400735392506?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d4db0d2fa
Old Aug 18, 2014 | 10:54 PM
TheShaddix's Avatar
TheShaddix
for example, if you go from 18 inch wheels that have 225/40/18 tires, you'd be using 225/35/19 tires on your 19 inch wheels. You always want to keep the overall diameter the same, otherwise it throws off the car's readouts. And that garage lip will not save you, it'll simply tear off. Your only solution is to really master your driveway approach. I've had a lot of lowered cars, way lower than the IS at any height, and the key is always extremely low speed, really steep angle of attack, and turned wheels. But you never want to turn your wheels if you're running an aggressive wheel setup or it'll bend your fenders.
Old Aug 18, 2014 | 11:38 PM
ph0nzie's Avatar
ph0nzie
Originally Posted by SCSurf
I practice that methodology, even when I got the car stock. I came from a 4Runner, so dropping down to a sport sedan with much lower ground clearance forced me to be particularly careful in navigating LA streets. My other dilemma, aside from protecting the front lip which has already been damaged, is entering and exiting steep driveways with steep angles. My office parking garage has one such scenario, which I would assume I would need to be almost parallel to the driveway to access. However, I'm limited by the radius at which I can turn to set myself up for this approach. Suggestions?
when you drop your car, there is not much you can do about scrapping. just more practice on taking bumps and dips at an angle so that you lead with your front tire when you go over a bump and not lead with your front bumper. i also have rsr down springs installed. unfortunately, 19" wheels wont lift your car up by much. good luck. a little scrapping is the price you pay to make your car look sexy.
Old Aug 19, 2014 | 07:07 AM
SCSurf's Avatar
SCSurf
Thanks guys. That really sucks. This is my first sedan and first time customizing and lowering a car (always had an SUV or truck) so I guess I'll just have to live with it. Over the years, while I'll improve my angle of approach minimize scraping, I'm sure I'll scrape a lot more times. Is there anyway to reinforce under the lip to minimize paint loss and damage?
Old Aug 19, 2014 | 07:19 AM
Dark9t316's Avatar
Dark9t316
Clear bra might help, it's expensive but it is thin and study.
ZarakiGold
IS - 1st Gen (2001-2005)
Jan 31, 2018 04:16 PM
siredward
RC F (2015-present)
Oct 16, 2016 01:51 PM
93SC300.
Sep 6, 2011 09:27 PM
tt061880
Jul 31, 2007 01:34 PM
aliga
Apr 30, 2004 02:06 PM
