Steps to modify the lane change flasher time change
Old 02-21-19, 10:56 AM
  #31
darkfire
darkfire's Avatar
Originally Posted by Burrcold
My dealer straight out said it couldn't be done. Once I did it on my own, I let them know that it can be done (they just kind of smirked and thought I "hacked it" somehow and said "we aren't responsible for damages as a result of you tinkering with the electronics" LOL).
Ugh. I stopped going to my dealer for questions for similar reasons. I keep getting bad info!
Chris
Old 02-21-19, 12:03 PM
  #32
LouisV
LouisV's Avatar
Originally Posted by kbbean08
Wanted to get my lane change flasher timing from 3 blinks to 5 and went to dealer to have them do it. Since they were busy, they just printed the steps out for me and I did it myself. It works and I thought I'd share.
The lane change flasher can be adjusted from no flashes, 3, 5, or 7 flashes
Adjustment procedure is:
1. Ignition OFF, hold the wiper switch in the all the way up (OFF) position, turn ignition ON, engine not running, and continue to hold the wiper switch in the OFF position for 5 seconds or more
2. Move wiper switch down 1 position and HOLD for 5 seconds or more
3. Move the wiper switch up to OFF position and hold for 5 seconds or more
4. Move wiper switch down 1 position and hold for 5 seconds or more
5. Release the wiper switch. The right turn signal should flash 1 time
6. Place the intermittent wiper rotary switch in one of the following 4 positions
-P1 - all the way down = 3 flashes
-P2 - 1 up from the bottom = 5 flashes
-P3 - 2 up from the bottom = 7 flashes
-P4 - All the way up = no flashes
7. Pull the turn signal switch down the lane change position (not the turn signal position) and release. The left turn signal should flash 2-4 times.
8. Turn the ignition OFF and then start the car and test.
This should also apply GS I think. Enjoy and hope this helps.
are the steps for all the secret features outlined somewhere?
Old 02-22-19, 06:39 AM
  #33
Asuarez18
Asuarez18's Avatar
Originally Posted by darkfire
For any 3IS newbies (like me), I followed this on my 2018 IS350 and it worked like a charm: https://www.youtube.com/watch?time_c...&v=wECSYAX3_70
Chris
Great Video!!! I will be trying this out this weekend, 3 blinks just isn't enough.
Old 02-22-19, 09:16 AM
  #34
SSworks
SSworks's Avatar
Just tried this on a 14 Is350 F sport and it works
Old 02-22-19, 09:31 AM
  #35
HOMER350
HOMER350's Avatar
Not that I've found.
That's the idea with this thread.
Programmable Personalized Settings
I will contact my local dealers and see what help they may be, then post in there.
Old 02-22-19, 11:44 AM
  #36
darkfire
darkfire's Avatar
Good luck!
Chris
Old 02-24-19, 02:46 PM
  #37
KYLexusMkr
KYLexusMkr's Avatar
Chris
Thanks for the post of this, worked great for my ‘17 IS300. Once I figured out that it had two setting up and only go down to the one set and not all the way down. Third time was the charm.
Old 02-25-19, 09:54 AM
  #38
nitroracer
nitroracer's Avatar
Chris
So much more informative than the description! Just did this to my 2018, as well. Thanks!
Old 02-26-19, 09:59 AM
  #39
darkfire
darkfire's Avatar
You're welcome!
Old 03-16-19, 01:10 PM
  #40
spindos
spindos's Avatar
Also wondering the same thing.
keycard198
09-05-20 04:08 AM
olecarman
11-12-15 10:42 PM
doodlebug
03-07-14 09:16 AM
JMarcum
04-03-11 07:09 AM
jmgoldsmit
01-04-10 10:07 AM
Quick Reply: Steps to modify the lane change flasher time change
