What's the best way to transfer songs to the Hard Drive?
Old 05-25-14, 05:50 PM
Aeromotive
Aeromotive's Avatar
Default What's the best way to transfer songs to the Hard Drive?
Hi all.
I'll be getting my USB 3IS tomorrow and I'm wondering how I can transfer songs to the car?
USB key (no pun intended)?
Burn a DVD and insert it?
Bluetooth?
From my phone?
All of the above?
Thanks!! Will post pics asap.
Old 05-25-14, 05:53 PM
4TehNguyen
4TehNguyen's Avatar
theres isnt a harddrive in the car, you can just play it off a USB. You can get the stubby USB drives like these
Old 05-25-14, 05:55 PM
Aeromotive
Aeromotive's Avatar
ORLY!? I was so sure there was one I'm probably confusing with my wife's car... Thanks for the quick answer!
How fast is this? I'm worried about lagggg/stuttering/jumping during playback?
Would a DVD be faster in comparison?
Old 05-25-14, 07:09 PM
4TehNguyen
4TehNguyen's Avatar
the USB is the quickest to access songs. Playing off the CD is actually quite slow
Old 05-26-14, 04:03 AM
IS3Fguy
IS3Fguy's Avatar
Actually there is a micro memory card that comes with it. It is behind the ML logo. Mine came with 32 GB.
Old 05-26-14, 05:42 AM
4TehNguyen
4TehNguyen's Avatar
thats the flash card for the navigation
Old 05-26-14, 09:01 AM
jhs82
jhs82's Avatar
Don't touch that! If you mess with it, you'll mess up the nav.
Besides, you can't read it in a PC.
Old 05-26-14, 09:13 AM
craigsager
craigsager's Avatar
I found this the other day. I took out the 32GB micro SD and threw away the car. Came up on an sd card!!!!
Old 06-16-14, 07:47 PM
Aeromotive
Aeromotive's Avatar
Update : I ended up buying exactly what 4TehNguyen posted and it worked flawlessly. No lag, no stutter, no delays. It's like having a Hard Drive in the car. Got the 32gb for almost the same price as a 16gb on Amazon. It's wayyyyy more than I need lol!
Thanks 4TehNguyen!
Old 06-16-14, 08:53 PM
dbs600
dbs600's Avatar
EXACTLY; WHAT HARD DRIVE!?
Absurd a $50k Lexus does not have a hard drive music collection; ABSURD.
Old 06-17-14, 04:36 AM
Aeromotive
Aeromotive's Avatar
I actually did because my wife's F30 has it, so I took it for granted. It's not a deal breaker though and a USB drive is actually even better because it's more practical! (to add/delete songs)
Old 06-17-14, 05:17 AM
4TehNguyen
4TehNguyen's Avatar
Thanks 4TehNguyen!
no problem. I would honestly rather have a USB drive than a harddrive in the car. What if that harddrive dies? $tealership time. But its no big deal if a USB dies. Even if this car had a HDD you'd still need a USB drive to load it, why not just skip the HDD and play off USB?
Old 06-17-14, 06:32 AM
HeMan26
HeMan26's Avatar
Hard drive would be nice as long as it is a solid state hard drive. You don't want a car equipped with a disk hard drive because it will go bad from vibrations over time. Does anyone know what the max memory size the car will read? I'm thinking about getting a solid state external hard drive that has about 250GB.
Old 06-17-14, 07:17 AM
Im2bz2p345
Im2bz2p345's Avatar
Not sure about the max storage size that the Lexus head unit can handle, but getting a SSD for simply playing music off of it is a complete waste imho. It's not like you really need the performance of the SSD.
Firstly, would a single USB port provide enough power to even run the SSD? Are the USB ports in the 3G IS USB 2.0 or USB 3.0? According to wikipedia: A unit load is defined as 100 mA in USB 2.0, and 150 mA in USB 3.0. A device may draw a maximum of 5 unit loads (500 mA) from a port in USB 2.0; 6 (900 mA) in USB 3.0.
Even if you could get it to power up, SSD's only have SATA output, you would need some type of adapter or enclosure so that you could get USB output.
The best solution is to get a portable USB stick (similar to what 4TehNguyen suggested) or if space is an issue, I would recommend something like this (
Amazon Amazon
) which has 500GB of space for around $50.
Hope this helps,
~ Im2bz2p345
Old 06-17-14, 07:42 AM
HeMan26
HeMan26's Avatar
The best solution is to get a portable USB stick (similar to what 4TehNguyen suggested) or if space is an issue, I would recommend something like this (http://www.amazon.com/BUFFALO-MiniSt...dp/B00D695IF4/) which has 500GB of space for around $50.
Hope this helps,
~ Im2bz2p345
I have a spare 250GB SSD that I can use. I'm going to get an enclosure with usb 2.0. I'll have to find one that has a separate dc power input so I can just use the cars dc power. Most of the enclosures use 5Vdc for power, so I should be able to use a separate usb power.
Quick Reply: What's the best way to transfer songs to the Hard Drive?
