Driver door rattle from bass
Ill work on getting pics but once you pop the panel out ou will see 4 clips that hold it to the other plastic piece. I put one piece next to the clip between the switch panel and the silver plastic. This is causing a tighter fit and adding pressure much like pushing it with your finger which was enough to stop the rattle for mine.
waleedj3is (05-26-17)
I had this issue too on my driver's side front door. I took it into the stealership and they said this was a common issue\complaint. They ended up ordering a new switch plate and replaced it. Now, I have no more issue with rattling.
nvm i just pretty much did what this guy did it works for now we will see how the elctric tape holds up
LEXUS GS: DOOR RATTLE FIX - YouTube
isosunrise
12-28-17 04:29 PM
