RS-R Down Springs Height Difference...Anyone Getting This???
Old Feb 9, 2014 | 11:23 AM
DexRox512's Avatar
DexRox512
Turkey Killer
Default RS-R Down Springs Height Difference...Anyone Getting This???
Hey guys. So I have a height issue with my down springs. The right side of my car is about 2 to 3/8's higher then the left. I am running 275/30/19 with a 45 offset in the rear and this difference is causing a tiny bit of rubbing over big dips on the left...nothing at all on the right. I've had RS-R swap the rear springs already...they've been super cool...but it's obviously the car. I have a 1 finger gap on the right side and on the left the fender touches my finger. Is this the gas tank??? What could it be??
Old Feb 9, 2014 | 11:50 AM
Shervin350's Avatar
Shervin350
even 2is have this problem lol
Old Feb 9, 2014 | 12:31 PM
ultran00b8's Avatar
ultran00b8
That's called Lexus lean. loool. Problem on the 2IS as well.
Old Feb 9, 2014 | 01:07 PM
DexRox512's Avatar
DexRox512
Turkey Killer
So if that's the case, wouldn't manufactures compensate for that so the car rides at the same height on both sides?
Old Feb 17, 2014 | 03:21 PM
DexRox512's Avatar
DexRox512
Turkey Killer
Just an update guys...RSR sent me a new set of rear springs, and after those settling, the ride height is almost 100% identical. Still rubbing on the drivers side though with the 275 tire.
Old Feb 17, 2014 | 07:46 PM
Stitch626's Avatar
Stitch626
Now that you mention it and reading your message this makes sense the whole "Lexus lean" problem lol. While my car rubbed on the 10.5 +32 wheels and 365 tires the real fender lining paint chipping was on the driver side only grrr dang it Lexus!
Old Feb 17, 2014 | 07:50 PM
LexFather
Guest
Posts: n/a
A 275 rear tire is super aggressive on the 3IS. Fitments are not the same as the 2IS and you can't modify the rear fenders. With a 255 there should be no issues.
I run 285s knowing good and damn well it will rub lol.
Old Feb 18, 2014 | 01:57 PM
DexRox512's Avatar
DexRox512
Turkey Killer
What do you think about a 265??? That's what I've ordered...
Old Feb 18, 2014 | 02:38 PM
Stitch626's Avatar
Stitch626
I'm on a 265 with my Vossen cvt 19" and have no rub issues you should be good
Old Feb 18, 2014 | 02:48 PM
Kybball#1's Avatar
Kybball#1
Well i guess i shouldnt even attempt to put my RSR Down spring on mine, im running a 285/25 in the rear, pretty sure id rub....grrrrrrr
Old Feb 18, 2014 | 03:10 PM
jaznraz's Avatar
jaznraz
DexRox - what is the wheel width of your rear 19's? You mentioned the offset but not the width....it makes a difference in regards to "what fits".
Old Feb 18, 2014 | 05:30 PM
DexRox512's Avatar
DexRox512
Turkey Killer
With the Velgen's it was 19x10.5 +45 and now with the F-Sport's I went back to it's 19x9 +40
Old Feb 19, 2014 | 04:40 AM
jaznraz's Avatar
jaznraz
When comparing those two wheels, the F Sport wheel will be much less aggressive - the outside of your rim will be appx 14mm (.55") further inside the fender as compared to your Velgen wheels. I don't see any reason why a 275/30/19 or a 265/30/19 wouldn't work with the F Sport wheels.
Old Feb 19, 2014 | 12:45 PM
ultran00b8's Avatar
ultran00b8
Do you have the old 2IS F Sport wheels? Can I see some pics of your new setup please.
DexRox512
Suspension and Brakes
Feb 15, 2014 10:13 AM
MashinA
12
Oct 3, 2010 08:11 PM
AltezzaIS3
IS - 1st Gen (2001-2005)
14
Jun 21, 2010 09:39 AM
kevintq
13
May 29, 2008 03:43 AM
97Soarer
Aug 10, 2005 09:56 AM
