From park to reverse, car won't move?
This has happened three times now on my 2023 IS350. After hours of sitting, start up car, put it in reverse, but it stays stuck in park. The gear shifter is in R, the display on the dash says R, but the "Park" light remains on in the dash. It feels like the parking brake is stuck on, but the engine just revs and the car doesn't move at all. Putting it back in Park, back to Reverse, doesn't help. Have to shut off engine and start over to get it to work. Any known problem here? This is on flat ground, inside a garage or outside.
I had this issue happen to me recently. I had to basically disengage the parking brake manually using the switch on the dash. Does this happen regularly?
Originally Posted by arentz07
(Post 11882815)
Question though. If it was all caused by the parking brake not releasing, wouldn't the car still have the ability to move when giving it gas? At least on older cars with a manual parking brake, you can still drive the car with it on. |
Originally Posted by Fizzboy7
(Post 11882949)
It's happened three to four times since new. Once in the garage, the other times outside in a parking lot. I forgot about the switch on the dash. That or shutting off car usually clears it. Just thought maybe it was a more known thing others have tackled, since I plan to bring it up at my next service.
Question though. If it was all caused by the parking brake not releasing, wouldn't the car still have the ability to move when giving it gas? At least on older cars with a manual parking brake, you can still drive the car with it on. Did the gauge cluster show a message like "Parking brake on"? I think mine did that at the time. |
(Post 11883168)
I am not sure about that, and I am not itching to find out. :D
This has happened to me three more times since I last replied to this thread, including today. I was able to resolve it every time by shifting back into park before trying again. Hmm...
(Post 11903427)
(Post 11903552)
Strange. I assume you plan on bringing it in for attention? Of course, share with us what they say or find...
Granted, this isn't every time I drive the car anyway. |
| All times are GMT -7. The time now is 04:58 PM. |
