Side mirror problem after bulb replacement
Hi guys I need some info if someone had the same issue.I replaced my side mirrors bulbs today and everything went grate except that after installing everything back both mirrors has some shines of dirt which doesn’t go away .I pushed it as i was supposed to in order to put it back in place and noticed some reflective damage in the glass but I thought it would go away after a while but it didn’t.Anyone had this issue before?
Thank you
Thank you
It sounds like it could be a failure of the electrochromatic coating that provides the dimming function. It's a very common problem on the in-car rear view mirror. Not sure if it affects the side view mirrors too.
Pictures from other threads:
Minor failure: https://www.clublexus.com/forums/is-...l#post10708828
Major failure: https://www.clublexus.com/forums/is-...ml#post7101039
krnboy817
15
Jan 17, 2021 07:01 AM
is.project
Jul 18, 2007 09:55 PM
