2011 ISF front seat problems
I created a thread on the ISF section but wanted to post it in here. I don’t know if the seats are the same or even compatible. But I figured I’ll ask for help here anyways. See below
Hello CL family! So I bought a set of white Isf seats for my car awhile back.
Took the old black seats out and installed the white ones. Everything bolted fine, plugged the connectors in and check for functionality before torquing the bolts down. Found out that all the buttons work except the part where the seats goes up and down. The odd part is the seat angle works just fine.
I removed all the plugs and plugged them in. Again, all functions work except the seat height adjustment. At this point I’m starting to get frustrated. I pull the seat back out and exchange the whole adjustment module with my old seat which I know was good. Still no joy. I put everything back together, install the drivers seat and move on the passenger hoping I won’t have any problems. Find out it’s doing the same exact thing as my drivers seats, all functions work except the seat height adjustment.
So, I wanted to check if I was messing something up with the install so I took out the passenger seat and put the old one back. Yup, the seat works perfectly.
I tried searching any info about the seats but all I could find is check the fuse, unplug and plug the connectors, wiggle the seat to make sure nothings preventing it from moving and lastly unplug the battery and reset it. Which I did all the above.
Has this happened to anyone? If so, how did you fix it. Any help would be great! Thanks everyone in advance!
Hop on any of the Lexus sites that offer "where used" and put in the two PN's for the upper level seat assembly and see what comes up.
I second this.... ^^
