Headlamp replacement & Ballast
Old Aug 13, 2021 | 04:43 AM
Johnb331's Avatar
Johnb331
Question Headlamp replacement & Ballast
I own a 2012 Lexus IS250 that runs like I bought it yesterday. I was hit by a 5-gallon bucket on the interstate one day and after repairs months ago have encounter issues with headlight assembly as well the ballast due to water infitration has corroided the contact. I am loooking for a pair to replace the factory installed set headlight assembly as well running lights. If possible the ballast for them as well. Anyone have a sites or know where I can find a pair of headlights as well the ballast for my baby?
Old Aug 13, 2021 | 09:02 AM
Zmon's Avatar
Zmon
I'm assuming you have the headlights with the LED strip? They're not cheap. You can find them used on eBay from anywhere between $300-500 for one side. Ballasts, along with bulbs, may or may not be included. If not, you can buy a generic replacement ballast for $43 from Amazon. From my experience with a cracked headlight, once water gets in, the ballast doesn't survive long so you'll likely be replacing it if the replacement headlight doesn't come with one.
There are generic aftermarket replacements, but they're typically marketed towards the 06-10 crowd. They also typically have terrible light output since they were designed for halogens in mind.
axis77
Mar 28, 2024 02:27 PM
driver1988
Mar 12, 2014 12:27 PM
Shorty79
Lighting
Aug 1, 2013 12:43 AM
jtork2
IS - 1st Gen (2001-2005)
Jul 13, 2013 09:24 PM
Fapout
Jan 3, 2012 09:11 PM
