IS250 with bad amp
Old Jun 2, 2021 | 06:35 AM
Dukenukemx's Avatar
Dukenukemx
Originally Posted by 2013FSport
@Dukenukemx
So what ever happened here? Did you do any further testing or just replace it?
I just replaced it. I couldn't figure out what the problem was in the amp. I also replaced the vent that was causing water to leak in and short out the amp. These sort of things need a diagram to properly fix it. Which is terrible because I ended up spending $250 for what I'm sure what a broken $5 electronic component.
Old Jun 2, 2021 | 10:02 AM
BoBoToo's Avatar
BoBoToo
Hi. I am trying to find the wiring diagram of this Pioneer amplifier GM-8157ZT (Toyota 86280-53110). I have seen a lot of diagrams online except the one for this particular model. Do you have the diagram to share? Thank you in advance.
Old Jun 2, 2021 | 11:12 AM
2013FSport's Avatar
2013FSport
If you still have the unit, I'd be willing to look at it. We'll unless the PCBA's were sprayed with something. Did I see that somewhere?
PM me... if I fix it, you pay shipping back as I have no use for it and you can sell it.
I've never seen Toyota release stuff like this at component level. Good luck!
Old Jun 5, 2021 | 06:56 PM
Dukenukemx's Avatar
Dukenukemx
I have no use for it now. Not unless the junk yard part breaks. I'm not even sure I still have it. I didn't spray anything on it. If I have half a mind I would rip out the amp system and put in an aftermarket, if it wasn't so damn integrated with the stereo. You can't even control the volume without the stupid amp.
tango72
Feb 12, 2021 09:37 PM
(f)-LEX-ible
Jan 28, 2019 07:08 PM
Shaq32
Aug 10, 2017 12:46 AM
venom1515
Jul 20, 2014 06:11 PM
SC2jz
Sep 30, 2003 12:32 PM
