ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   IS - 2nd Gen (2006-2013) (https://www.clublexus.com/forums/is-2nd-gen-2006-2013-163/)
-   -   Car won't start unless the engine is cold... (https://www.clublexus.com/forums/is-2nd-gen-2006-2013/942670-car-wont-start-unless-the-engine-is-cold.html)
kenngnz Apr 18, 2020 11:55 AM
My is250 is at 170k miles now and it only starts when the engine is cold. Once it starts, it drives normally, but I can't turn it back on after around 5 minutes of it being off. I have to wait until the engine is completely cold again in order for it to turn on. Anybody know how I can fix this?
skyfox Apr 18, 2020 09:08 PM
When this happen next time, Open the Gas cap and close it again and see if that fixes the problem. Also check if the gas cap seal is in good shape. How old is the battery and when was the last time plugs were changed? I assume car cranks when hot but doesn't start?
Thannp Apr 18, 2020 11:31 PM
Check your starter motor. Maybe it is on its way out. Mine was acting like this and found it to be a problem
Gville350 Apr 20, 2020 09:02 AM
So what exactly happens when you attempt to start the car when hot/warm/operating temp? Be specific. Does the starter attempt to turn over the engine, but the engine just doesn't fire?
Any CELs?
kenngnz May 3, 2020 02:46 PM
Replaced the starter and everything seems to work fine. A huge thanks to you all for helping!
