Opinions and advice on Idle
Old Dec 15, 2019 | 02:12 PM
bryceis250's Avatar
bryceis250
Default Opinions and advice on Idle
HI guys. Ive got a very slight almost unnoticeable hiccup, or skip, when the cars warming up. its never caused a CEL. its got a new MAFS, clean filter, ive cleaned the throttle body, new PCV. plugs are still in range. im not sure what to check from here and start wondering about coil packs and what not. the car shakes and vibrates at stop signs and stop lights now, never used to, but im not saying one happened with the other. opinion, advice or reference to proper prior threads appreciated. thanks again !
Old Dec 15, 2019 | 03:43 PM
2013FSport's Avatar
2013FSport
Perhaps check the compression and if all is well, entertain the idea of walnut blasting the intake. Everything you wrote is often what 250 owners experience when carbon buildup is a factor.
Old Dec 17, 2019 | 10:12 AM
gone2morro's Avatar
gone2morro
Seafoam works well too....for me, for the carbon buildup. Just pour in the tank at every oil change. Some people spray it into the intake (youtube has videos) which also works well. If I feel it hesitate before an oil change, I'll add a bottle on next fill up with gas. My 2008 is at 192,000 miles and never had the walnut blasting. Good luck!
JulezLexx
Sep 10, 2019 09:37 AM
bklynchris
Oct 10, 2012 10:40 AM
Och
Oct 20, 2008 06:59 PM
kuWuPt
Feb 22, 2008 11:23 AM
TRD_Power
Maintenance
Jan 4, 2006 10:24 AM
