A Special SItuation
Hello everyone, I am new and novice when it comes to auto maintenance. I have 06 IS250 AWD, first owner. I don't drive this car that often, it only has 72,000 km (NOT MILES), 17,000 km on highway. I did the regular services during the warranty period, after that only did maintenance when needed; however, I did all the recalls. With this mileage and age what kind of services should I do? I don't like the dealer close to me (they don't give loaner car nor they have enough shuttle service) and wish to know what should I do so I can take the car to specific shops to do the work unless there's something that's critical and has to be done by Lexus.
Thank you very much for your suggestions/advises and help.
I forgot to mention that my my car is mostly parked outdoor, you know how much is snow Alberta gets in its long winter
What about these ones (listed in Lexus maintenance manual under 36 and 54 months intervals)?
____Axle shaft boots
____Ball joints and dust covers
____Body
____Brake lines and hoses
____Exhaust pipes and mountings
____Front differential oil
____Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
____Fuel tank cap gasket
____Rack and pinion assembly
____Rear differential oil
____Steering linkage and boots
The transmission is "sealed" given the low mileage do you really think it should be also changed?
Buy about 4 1lb bags of desiccant.
1 in the trunk
2 cabin
1 under the hood.
This will absorb moisture so it doesn't mildew.
Cover the dash, door panels, seats. Although the glass has UV protectio sitting in the same spot will take its toll.
Tires. Tires can dry rot. Look at the date code. If more than 5 years old I'd inspect them thoroughly.
I know everyone said all fluids, but flush the brake fluid. Toyota 10 year antifreeze is good stuff. I would leave it for 8 years.
So why have it as an ornament? Why not drive it?
1 in the trunk
2 cabin
1 under the hood.
1 in the trunk
2 cabin
1 under the hood.
1 in the trunk
2 cabin
1 under the hood.
I am shopping for a specially designed/built capsule to park my IS in,
I live 7 minutes away from my work. I have another family car. I am not a fan of consumerism.
Brklynkid
GX - 1st Gen (2003-2009)
Apr 9, 2019 09:19 AM
WhatYaGot
Jan 7, 2008 05:00 PM
