FM Radio Stopped Working Suddenly
Old 04-23-18, 09:13 PM
nzasian88
nzasian88's Avatar
Default FM Radio Stopped Working Suddenly
Hi All
Recently was playing music on my non-nav IS250 stereo using Aux Cable, then switched over to FM radio. Worked for about 30 seconds then all of a sudden no sound from radio. I tried tuning to a different station, but the "Seek Track" function wasn't able to find any channels. Still works with CD and Aux, so I can comfortably rule out the common AMP problem.
Any suggestions? Have a feeling its a "radio/Antenna" specific fuse here.
Cheers
Old 04-23-18, 09:35 PM
DennisMik
DennisMik's Avatar
I don't think there is a specific fuse for this. There is a fuse for the radio and that powers all the sections of the radio. Other than the radio itself, there is an antenna amplifier unit that could be bad. It is in the headliner above the rear window.
Old 04-23-18, 10:35 PM
whitebeast
whitebeast's Avatar
Try AM radio to see if it works
Old 04-23-18, 10:36 PM
nzasian88
nzasian88's Avatar
Nope AM and FM, nothing
Old 04-23-18, 10:40 PM
whitebeast
whitebeast's Avatar
Most likely is the radio itself. I have seen a few of them for same problem. CD works fine but not radio or radio works fine but no sound from cd player
Old 04-24-18, 02:49 PM
DMV350
DMV350's Avatar
Old 04-24-18, 03:05 PM
Zmon
Zmon's Avatar
Originally Posted by DMV350
Sort of related question...
Anyone else have their rear defroster interfere with FM radio signal?
Yep, it interferes with mine.
Old 04-25-18, 08:12 AM
2013FSport
2013FSport's Avatar
Received 1,475 Likes on 1,230 Posts
Mine seems OK. You know the antenna is integrated into the upper section of the rear glass, yes?
Does make it hum or signal loss or ??
Old 04-25-18, 08:53 AM
Zynthe
Zynthe's Avatar
When it rains in my area sometimes my radio does work. When I turn if off and on I hear a pop sound from my speakers but no audio. Its hit or miss when it rains. Sometimes itll work, other times it doesnt.
Does anyone know what could be the issue?
Old 04-25-18, 09:07 AM
DMV350
DMV350's Avatar
Old 04-04-20, 12:56 PM
Bill Dowd
Bill Dowd's Avatar
The only thig I can say is that the info Margate 330 sent on his link said showed how to put In different codes while the radio was on.
then it just started to work again can't explain it just happy it's working.
Ward
04-17-19 06:16 AM
osomegaSC
Performance & Maintenance
03-23-17 08:30 AM
monkfury
RX - 3rd Gen (2010-2015)
04-21-14 12:28 AM
Gsnuggs
09-16-12 12:07 PM
Quick Reply: FM Radio Stopped Working Suddenly
