No check engine light, engine won’t turn over...
Old Mar 23, 2018 | 02:25 PM
VicThaDish's Avatar
VicThaDish
Default No check engine light, engine won’t turn over...
Hello ClubLexus,
I have a 2006 IS250 RWD 6MT. I was driving home a few weeks ago when the car shut off. It has dash lights, battery voltage at 12.6v, no check engine light and the engine will not turn over. With the clutch applied, the green light on the start button comes on, but the engine won’t turn over. I tried to hook up a scanner to get codes, but it cannot communicate with the ecu. I check fuses and couldn’t find any fuse blown. Any help would be greatly appreciated.
Thanks,
Victor
Old Mar 23, 2018 | 07:09 PM
MikeFig82's Avatar
MikeFig82
Look to the possibility of it being the fuel pressure sensor. The below threads will give you some insight.
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/881579-stalled-while-driving.html#post10138558
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/851386-replacing-fuel-pressure-sensor-what-should-i-know.html
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/850074-2009-is250-will-not-start-fuel-pressure-sensor.html
Old Mar 23, 2018 | 09:46 PM
VicThaDish's Avatar
VicThaDish
Awesome! Thank you! That’s exactly what it was. Picking up the part tomorrow to fix it finally. I really appreciate all the help!!
Old Mar 24, 2018 | 09:27 AM
2013FSport's Avatar
2013FSport
Arrow
https://www.clublexus.com/forums/is-...l#post10138558
https://www.clublexus.com/forums/is-...ld-i-know.html
https://www.clublexus.com/forums/is-...re-sensor.html
There should be a No Start Sticky with all these aged related failures popping up of late.
Kvkosty
Mar 2, 2018 11:47 AM
4renerr
Aug 11, 2017 02:49 PM
LexusTime2
Jan 20, 2007 01:07 PM
Belement
Oct 3, 2006 06:45 PM
PearlLex
12
Aug 9, 2004 11:57 PM
