ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   IS - 2nd Gen (2006-2013) (https://www.clublexus.com/forums/is-2nd-gen-2006-2013-163/)
-   -   Car won't start (https://www.clublexus.com/forums/is-2nd-gen-2006-2013/882467-car-wont-start.html)
Michael481 Mar 4, 2018 02:49 PM
Car won't start
Ok so I posted before about my car stopped working out of no where at 711, the P/S light turned on and it won't cranck over, everything and everyone pointed at the fuel pressure sensor, i just changed it, and still having the same problem...
MikeFig82 Mar 4, 2018 04:42 PM
Check your Link fuse next to the battery. I read your other post. You tried to jump start the car many times. This can also kill the battery again. I recommend getting it load tested.
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/692433-diy-fusible-link-removal.html
Another thing these cars tend to get flooded with multiple crank no starts. You can try some starting fluid to see if it helps get it going.
Michael481 Mar 4, 2018 06:02 PM
starter fluid, the car doesn't use starter fluid, its all electrical
Michael481 Mar 4, 2018 06:14 PM
Fuse link
How do I check if the fuse link isn't good? Everything pointed to a bad fuel pressure sensor
MikeFig82 Mar 4, 2018 07:03 PM
I would recommend spraying some into the throttle body then put the intake pipe back on. Don't over do it.
MikeFig82 Mar 4, 2018 07:05 PM
The fuse link is next to the battery. Check if one of the copper terminal isn't busted open. It will be noticible if you shine some light on the fuse box itself. See the thread link in the previous post.
