Rear Wheel Bearing DIY
Having done a search...this is the most recent one I found that has anything to do with the rears...https://www.clublexus.com/forums/is-...ust-cover.html
My rear wheel bearings were replaced and this aluminum cover was left off by the previous owner's mechanic on both sides. I would like to do this myself and am told that the aluminum protective cover actually needs to be "pressed" on the axle...(this advice from the dealer tech BTW)
My "Check VSC" warning has been coming on too...also a code is registering that points to debris on the left rear speed sensor...which I understand is closely related too and reading from the bearing itself?
Thanks in advance
Thanks in advance
I guess to make it perfectly clear I am asking if anyone has replaced their rear wheel bearings, and/or rear axles. If so, did you do it yourself? If you did, and care to share your experience, please PM me.
