Belt Tension Question
Hi Friends!
I am having a bit of squeaking belt issues on my 350. I initially replaced the belt thinking it was time. The squeaking stopped. Fast forward roughly 500 miles, belt noise is back. How Can i tighten the tensioner ? I noticed that my belt is not as "tight" as the day i had belt replaced. I tried to tighten it with a 14mm on the tensioner and turned towards the passenger side but the tensioner just moves and loosens the belt and gets back to its place once i stop. This isn't really making the belt tension any stronger so What am i doing wrong? Why wont the belt tighten up?
Do i have to completely relieve the tension 1st? Or can i just increase the tension from its position as-is?
I am sure there is some other issue at the moment such as a bad tensioner, which i will replace. But before i do that I want to confirm again by getting the tension back to normal and see if it gets loose again before I replace the tensioner.
Thank you!
Thank you!
rx7guy
04-29-09 12:27 PM
