Stripped Allen Bolt (Intake Manifold)
hey man, im currently in the same boat but somehow I just can't get the bolt head to bust. (Im using an impact drill)
any tips/tricks on how you got yours to break?... hopefully you'd recall, i did notice this post is a few years old. thanks in advance!
https://www.clublexus.com/forums/is-...ml#post9805716
I used a bit that was about the width as the opening of the hexagon. If you removed another bolt you can match the size of your drill bit to the width of the threads. Note in a few pics down, the drilled out hexagon bolt, the interior shape is gone.
Just have to go slow until the head becomes separated from the threaded region.
Hope this helps!
My scenario was a little bit different, the end of th Allen wrench broke inside the bolt.
Luckily pulling around w a sharp pick tool and a magnet, the broken piece came off. Did find those in the pocket manilfold holes to be the most difficult to take out, break out from been so tight.
WD40 works with stuck nuts-bolts. Spray some a few days before you unscrew them, works all the time.
