ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   IS - 2nd Gen (2006-2013) (https://www.clublexus.com/forums/is-2nd-gen-2006-2013-163/)
-   -   2007 IS250 power steering won't work! (https://www.clublexus.com/forums/is-2nd-gen-2006-2013/842107-2007-is250-power-steering-wont-work.html)
Chey250 Dec 17, 2016 01:06 PM
I recently purchased this car from someone my father knows. The car has been wrecked twice and my father has fixed it both times. We've had a few other issues with the car that we've fixed but we can't seem to fix the power steering. P/S light is on, VSC light, & CEL. We've checked all fuses, we've unplugged every plug, checked the EPS module located under the battery, etc. Also, they had the fuse plate (the white fuse cluster on the passenger side inside the fuse box) replaced before, the alternator fuse was blown. Really need some advice from Lexus experts. I've never owned a car with this much technology! Any help is greatly appreciated.
Gville350 Dec 17, 2016 07:38 PM
I'd suggest maybe looking into a replacement steering ecu. Good excuse to upgrade to an IS-F ecu! ;) But before you do that, ensure that no wiring to the ECU got cut/pinched during one of these accidents.
Chey250 Dec 17, 2016 10:39 PM
& where can I find a new one at? I looked once but don't recall finding a NEW one anywhere.
Gville350 Dec 18, 2016 05:56 PM
Available at any Lexus dealership, or I found this on ebay :
http://www.ebay.com/itm/LEXUS-ISF-IS...FYPOYS&vxp=mtr
Chey250 Dec 18, 2016 06:44 PM
thanks so much. One more quick question. There's a plug right by my battery, it has 2 wires, one is black with a red stripe & then other is black with a yellow stripe. Can you tell me what these go to? We unplugged them while the car is running & absolutely nothing happened, nothing even went off.
BLAD350 Dec 20, 2016 05:03 PM
Theres a big difference between modifying and repairing a car. Most people here dont know much about repairing and "upgrading" to a newer ecu prob wont fix your problem. There is prob damage in your harness after the accidents and your steering ecu isnt receiving the correct voltage or its circuit ground is faulty. Verify your alternator is working correctly and if it is go trace the problem in the harness as it will manifest all of the problems you are experiencing.
flynryan Dec 21, 2016 06:02 PM
Curious if you got this fixed and what it was?
When our alternator was acting up it would make the power steering not work all the time. After figuring out it was the alternator I replaced it with a new one from Oriellys and havent had a problem since.
Chey250 Dec 21, 2016 10:00 PM
it is not fixed. It still sitting in the same place unfortunately, kinda to the point where I'm gonna drive it without the power steering. But I did notice they had replaced the fuse panel because of the blown alternator fuse. May give that a try.
flynryan Dec 21, 2016 10:06 PM
Easiest way is to just put a volt meter on the battery while the car is at idle. Should read around 13.5 to 14 ish volts. Mine was intermittent so it was a little harder to diagnose.
Filthiest Jan 30, 2017 09:24 PM
It seems like a weak alternator, get it tested!
Chris80 Mar 6, 2017 12:16 AM
Hi
I have the same problem rmine. Had you manage to fix it?
Koalareal1 Apr 3, 2017 01:35 PM
Hi you have bad ecu module power steering I have before exactly you problem I check in Lexus for fix is 4,000 I fix by myself for 150dollar you need check the power steering computer is the p/s
