(CDN) Mileage Very Poor.
Old 03-14-16, 10:46 AM
obis250awd
obis250awd's Avatar
Default (CDN) Mileage Very Poor.
LONG STORY SHORT,
I use to have an INTAKE for my car, I reverted back to stock intake.
My mileage went from 460/km per 60L tank to ..
340/km per 60L
360/km per 60L
After 3 fill-ups I am now getting 400/km.. But barley close ..
My meters say weird things on idle and jump from 30/L per 100km tank..
The numbers in the photos attached will change as well and just keep increasing.
Its really starting to bother me I dont know much about cars so any information you guys have is greatly appreciated
Old 03-14-16, 11:39 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
What year is the car? Why did you take the intake out? Is that city driving or highway? Are there any engine codes?
Previously in my IS250 6MT I would get around 420-450km in the city for about 60L, which isn't that great either, but my 6MT is rated for worse mileage (just barely) than the AWD IS250 6AT. I've always run a stock intake and I don't hold back on the throttle.
Something seems up with your car, though I'm not entirely sure the intake would be to blame.
Jeff
Old 03-14-16, 12:14 PM
Bichon
Super Moderator
Bichon's Avatar
I notice that you are looking at the "TANK AVG" when the tank is full. It's similarly misleading to look at the "AVG" display shortly after resetting it. Both are more of an instantaneous readout than an average until you've logged a significant amount of kilometers.
Old 03-14-16, 12:34 PM
Eduskator
Eduskator's Avatar
What's the condition of the intake you just put in?
Was it new or an old one? Something might be clogged.
Old 03-14-16, 01:27 PM
obis250awd
obis250awd's Avatar
90% city driving, i only drive city , rarely hwy
what do you mean by engine code?
2011 IS250 AWD
I went from TAKEDA INTAKE back into my STOCK
I was going to sell my car during this time (tradein) so I went back to stock and sold my intake
however I ended up keeping my car as the trade in value was too low
SINCE THEN my mileage has been 330- under
My last tank was 410..
But I am wondering why it is so hard to get back into the 450's+
I fill 91 octane
and do regular oil changes at 6000km
Old 03-14-16, 01:40 PM
Gville350
Gville350's Avatar
Did you disconnect the battery for 20 minutes to force the car to re-learn after disconnecting the intake?
Old 03-14-16, 01:47 PM
obis250awd
obis250awd's Avatar
No I didn't
any thing I should do now?
Old 03-14-16, 04:16 PM
20LS01
20LS01's Avatar
it's likely the stock air filter causing this.
Aftermarket air filters have better airflow and i think this makes the engine work less harder therefore providing better gas mileage. I saw a bump in gas mileage after switching air filters.
Old 03-14-16, 04:30 PM
Gville350
Gville350's Avatar
Originally Posted by obis250awd
No I didn't
Yes, go ahead and do it now. It'll force the car to relearn using the now stock intake vs the aftermarket one.
Old 03-14-16, 07:46 PM
Bichon
Super Moderator
Bichon's Avatar
This is simply not the case. Engine airflow at anything other than WOT is intentionally restricted by the throttle butterfly. In a modern closed loop system, the computer will simply open the throttle a bit further to compensate for an air filter that doesn't flow as well (or one that is dirty), and will close the throttle to compensate for one that flows better.
Reference from SAE website: http://papers.sae.org/2012-01-1717/
Old 03-15-16, 12:54 AM
604GSE21
604GSE21's Avatar
i get around 11-13L/100km in the city and lowest 7.9L/100km hwy driving down to seattle w/ gentle throttle on my IS350 rwd and i get roughly 450km out of a tank w/ mix driving... maybe your car is quieter w/o the aftermarket intake and you had to floor it more to hear the engine lol...
Old 03-15-16, 05:24 AM
Eduskator
Eduskator's Avatar
Did you put back your old intake + filter or did you change the filter?
If you put back the old one that was lying around in your garage, your issue might just be here. Change your filter!
My 2011 AWD IS250 is doing 12-13 L / 100km in town right now. Was doing 14-15L in extreme cold. Highway is around 9L/100km.
Air filter was changed right before winter.
Old 03-15-16, 08:20 AM
Bichon
Super Moderator
Bichon's Avatar
Sorry to repeat the same point I made earlier, but the relationship between dirty air filters and reduced mileage was only true with old school cars. On a modern car with a closed loop control and a MAF sensor, the computer compensates for a poor flowing filter by opening the throttle wider and injecting the same amount of fuel.
Here is another reference (conclusion posted below), this one from research done by the department of energy: https://www.fueleconomy.gov/feg/pdfs...02_26_2009.pdf
The goal of this study was to explore the effects of a clogged air filter on the fuel economy of vehicles
operating over prescribed test cycles. Three newer vehicles (a 2007 Buick Lucerne, a 2006 Dodge
Charger, and a 2003 Toyota Camry) and an older carbureted vehicle were tested.
Results show that clogging the air filter has no significant effect on the fuel economy of the newer
vehicles (all fuel injected with closed-loop control and one equipped with MDS). The engine control
systems were able to maintain the desired AFR regardless of intake restrictions, and therefore fuel
consumption was not increased. The carbureted engine did show a decrease in fuel economy with
increasing restriction. However, the level of restriction required to cause a substantial (10–15%) decrease
in fuel economy (such as that cited in the literature3,4
) was so severe that the vehicle was almost
undrivable. Acceleration performance on all vehicles was improved with a clean air filter.
Old 03-15-16, 08:55 AM
Eduskator
Eduskator's Avatar
Thanks for the link! Very good information.
OP's issue might be solved by doing the learning procedures.
Also, I would recommend not to rely on the dashboard's MPG and calculate it manually (way more precise).
If you top off your gas tank every time, it'll work. Restart the trip meter every time you fuelup as well. Divide the liters you put by the KMs you did since last fuelup.
Example : I put 45 liters and my trip meter indicates 350kms. 45 liters divided by 3.5 = 12.85L/100KM
I know by fact that my car always reads below the ''real'' consumption. For instance, it was doing 15.9L/100km during extreme cold this winter while my car's TANK MPG was showing 14-15. It's a big gap.
Old 03-15-16, 09:40 AM
obis250awd
obis250awd's Avatar
hey! yes It was in my garage and I will look into changing my filter my most recent tank is 420km..
still not happy as I was gettign 460+ before
Quick Reply: (CDN) Mileage Very Poor.
