F-Sport Short Shift Kit for 250 6MT
#31
2IS/2RX/4RX
This part is discontinued and no longer produced with no stock left. The only ones you can find are used.
It would be pretty easy to have the part made to be honest, however the tricky part is the extended rubber boot. If someone could mold that, I could have these (or even better) quickshifter kits made again.
I may look into having that done at some point, I'm sure some 3D printing place can do a flexible material for the boot or similar. As I said, getting the metal pieces done up would be no problem at all.
Jeff
Jeff
#32
Keeping it Real
Correct, the original F-Sport shifter increased the length below the fulcrum by 25mm. I would probably do 30mm if I was doing it.
I also recently found out that the 3D printer I have access to is able to print flexible rubber parts. I will be investigating further...
Jeff
Jeff
Individual
17
08-15-14 05:23 PM
Wunko
12-03-12 06:46 PM
