Dash cam hardwire fuses
Hello,
I'm trying to hardwire my dashcam with power magic pro for parking mode. Which fuses should I use? Currently I'm using the LH-IG one for the ACC and FR S/HTR LH for the battery.
When the car is on, I cannot switch the power magic pro off. However the power magic pro doesn't work when the car is off. What am I doing wrong?
Should I use a fuse tap for each fuse? My current set up; I just wrapped the wire around the fuse.
yes you should use a fuse tap and you should get a multimeter and test those fuses to see which one works best. i forget the one i am using but i had to use a meter to find the right one to use for my dashcam.
