So i purchased a 2007 IS250 and notice the inner tail-light doesn't work when my lights are on. I quickly learned they can't be replaced (called parts store, they dont carry the bulbs and no way to gain access to the bulbs)
How do i replace it? Or do i have to buy a new light? If so can anyone point me in the right direction for a inner taillight (passenger side)
Pretty sure they are LED and I haven't heard of them having issues. I would check that they are plugged in properly. You will have to open the trunk lid and remove the carpeting to get behind the light. I would also check that there's voltage at the plug.
I have confirmed it is the actual bulbs/taillight because i removed both sides and plugged the driver side in the passenger side and it worked fine.
While searching for something else, I ran across this old thread. I believe the answers to be incorrect. If an LED were the problem, It would be one LED, not both. The connector or the harness is at fault. AMHIK!
