2012 oem led headlights problem
Old Sep 28, 2015 | 08:08 PM
RDIS250AWD's Avatar
RDIS250AWD
Default 2012 oem led headlights problem
Honestly I don't know when this problem started BC I've put it off for so long but I've had an issue with my low beams pointing low. So I've taken the time to finally address this issue and I'm pretty positive turning the screw clockwise is gonna move the beam up. Well it did move up but barely. I've turned it over 100 times. On top of that I totally forgot that when u first start the car the lights move up and down until my buddy started his 2011 is350. So my headlights haven't done that for the longest time that I totally forgot about that function. Perhaps the mechanism that moves the projector up and down is broken? So my question is besides buying new headlights, how can I fix this? Perhaps retrofit new projectors?
Old Sep 28, 2015 | 10:28 PM
PNice972's Avatar
PNice972
2011+ LED headlights do not move up and down, they are stationary.
Old Sep 28, 2015 | 10:50 PM
RDIS250AWD's Avatar
RDIS250AWD
If you're thinking of the afs function you're correct they don't move left and right when u turn your car but as for as start up they definite go up, and then down into place. I know this for sure BC my buddy turned on his 2011 is350 fsport. And it did do so on mine before
Old Sep 28, 2015 | 11:24 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
They have auto-leveling, and there is an adjustment to adjust the level on the headlights as well. It does take quite a few turns to move the lights, but they should move. Were you having issues with both of them, or just one?
Jeff
Old Sep 29, 2015 | 06:36 AM
RDIS250AWD's Avatar
RDIS250AWD
Jeff
Both of them I actually did roughly 200 full rotation on both. And they moved but they are still pretty low especially when compared to my buddies car
Old Sep 29, 2015 | 06:51 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Are you sure you were moving the up/down adjuster and not the left/right adjuster? (It moves the headlights slightly up/down, but mostly left/right).
Jeff
Old Sep 29, 2015 | 09:11 AM
RDIS250AWD's Avatar
RDIS250AWD
Jeff
Correct I follow the DIY thread on here.
Old Sep 29, 2015 | 07:38 PM
RDIS250AWD's Avatar
RDIS250AWD
So if I bought retrofitted projectors would it fix this issue? Has anyone retrofitted these headlights?
ms2619
Dec 16, 2015 01:28 AM
Hbhandal
Jun 25, 2015 12:09 AM
soleeasii
Jul 26, 2013 09:06 PM
sgmbab
Aug 5, 2012 04:22 PM
CCJ22
Jun 22, 2012 05:32 PM
