DRL lights not working
Old 06-09-15, 07:54 PM
Rootrick
Rootrick's Avatar
Unhappy DRL lights not working
Hello there,
So a few days ago I've purchased a set of LED DRL's light for my 2010 Lexus IS350 and proceed to install them.
After I've installed the LED DRL's they won't turn on at all, so I've tried putting the old bulbs back and those won't turn on either.
A friend of mine told that i might blew up a fuse in the car. Now, I am trying to find the DRL light fuse in the engine fuse box, Driver side fuse box and passenger side fuse box but i cannot find it. I've looked in the owner's manual and it has all the description for all the fuses in the car except the one for DRL lights, it might be that is not named DRL lights fuse or something like that. So i was hoping that someone would know which fuse im suposse to look for.
Please help
Old 06-09-15, 10:04 PM
pheonix72
pheonix72's Avatar
The same thing happened to me when I installed the Decoder and LED DRL. The fuse is in the driver's side fuse box. It is on the second set/group of fuses underneath so you will have to remove the small section of the fuse box on top. I will try to snap a pic if you can't figure it out.
Btw, the good news is that the fuse hasn't blown again since then.
Old 06-10-15, 05:23 PM
Rootrick
Rootrick's Avatar
Pheonix,
Thanks for the info man!
What # is the fuse? do you remember? i think is a # 10
Old 06-10-15, 05:52 PM
Rootrick
Rootrick's Avatar
Could you please take a screenshot?
Thanks a lot!
Old 06-11-15, 09:45 PM
pheonix72
pheonix72's Avatar
Thanks a lot!
Sorry but I have been so busy. I will try to take a picture this weekend if you haven't figured it out yet. However, I know for sure it is on the lower bank of fuses and one of those on the outside (closer to the center of the engine bay)
Old 06-13-15, 04:00 PM
pheonix72
pheonix72's Avatar
Here you go. It is the 15A fuse, labeled "H-LP UPR". It is located on the controller block so you have to remove the block by pressing the 2 clips on the end of the block. Good luck
Old 06-20-15, 09:20 AM
Rootrick
Rootrick's Avatar
pheonix72,
I believe you have a different Fuse Box because I couldn't find that fuse anywhere in my car.
Is that a picture of the fuse box that's under the hood of your car?
Thanks
Donmemon
ES - 6th Gen (2013-2018)
12-03-17 02:06 PM
abatodu
GX - 1st Gen (2004-2009)
12-26-14 07:58 PM
ReyRey305
08-08-14 09:36 PM
MALYOU
11-11-13 01:34 PM
Hpnotiq
09-01-13 03:00 PM
Quick Reply: DRL lights not working
