Anyone here have the iVIC from Vaistech?
I am considering buying the module but wanted to know if it restricts any of my cars functionality.
Originally Posted by Zinda
(Post 8514677)
iVIC application guide can be found here: http://www.vaistech.com/manuals/iVIC%20App%20Guide.pdf Thank you! |
What is the difference between 5d and 6d? Also do I have to be connected to the USB if I want to stream music to the unit via bluetooth? Will I be able to control my randomizer on my S4 music app and skip songs via the steering wheel? Have you guys figured out a way to pair the voice control with google now?
(Post 8515281)
Don't know what you mean by randomiser but you can certainly skip songs using the steering wheel. |
I use the 6D that was installed professionally. As far I can I tell, if you are using an iPod on the iPod interface, it restricts your steering wheel functionality. This is probably because they expect you to use the iPod itself to navigate through songs. If you use the standard flash drive/hard drive interface that mimics the OEM audio interface, all steering wheel functions work the same.
Jay |
I had the ml+ and upgraded to the ivic in my 2008 is350. I upgraded from iPhone 4 to iPhone 5s and needed the newer version. I think it works great and is all I listen to. I mostly do pandora but do use the iPhone app and music player as well. All steering wheel functions work including track changing and volume. I would highly recommend the unit to anyone that listens to a lot of music. I think it is very user friendly and is easy to navigate. As far as the apps of calendar and map I have not used them much. They work as advertised but I really do not need to use them in the car.
How easy is the installation? Where is a great place to put the wiring for the phone. I like stealth options in this case!
(Post 8521759)
(Post 8521759)
the other thing to keep in mind is when pulling your nav out and putting it back in, be careful not to destroy your dash. I put my unit in the glovebox and I turned my ashtray into a dock for my phone by drilling a hole in the bottom and gluing the connector so it sticks out. https://lh4.googleusercontent.com/qM...xpY=w1280-h724 https://lh4.googleusercontent.com/-t...o/IMAG0134.jpg |
I just got the iVIC and it is good right now I even got my phone charging WHILE using MHL. I used a omni rom for my old samsung s3 which got rid of all the nonsense samsung puts on their phone.
Unit works great only limited by my navigation screen. By the way touchwiz is not agreeable with ivic and you will have to get novalauncher! |
makes the car soo much better to live with, heres what i did
How did you fit it under there? I already have some sort of box there that I have no idea!
I have the 5D in my IS250 and I love it. There's a learning curve and after some griping and complaining, it was smooth sailing. I now drive my IS350 and took a drive in my 250 this past Saturday for the first time since August and remembered how much I love my iViC. I'm a music head and I love being able to have my music, pandora, spotify and whatever else is running AND have my text messages read outloud on the audio system. It's very convenient.
Unfortunately I am going to be selling my car eventually and need to get it out. I'm tempted to get the 6D for my IS350. |
I think the ivic port application on android is slightly buggy though. Definitely right about the learning curve...
Originally Posted by VaisTech
(Post 8515221)
iVIC retains all factory installed equipment with all compatible cars.
