Stiff Brake Pedal When Parked More Than 8 Hrs.
Old 09-25-13, 03:03 AM
WhatYaGot
WhatYaGot's Avatar
Question Stiff Brake Pedal When Parked More Than 1 Hr.
My brake pedal gets very stiff to the point I have to press kind of hard to start the car. This only happens if the car is parked for more than 1 hour. Started to happen about 2 weeks ago and hasn't gone away. I'm thinking brake booster or some kind of small vacuum leak? Any thoughts? The car just hit 150,000.
Attached Thumbnails Stiff Brake Pedal When Parked More Than 8 Hrs.-cluster.jpg
Old 09-25-13, 09:05 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Most likely it's the brake booster.
Jeff
Old 09-25-13, 12:47 PM
Gville350
Gville350's Avatar
^I'd agree! On hot summer afternoons did you find the pedal slowly creeping to the floor when stuck at a light/traffic? My old Civic did this and a new booster and master cylinder (pick-a-part combo) fixed it.
GL!
Old 09-29-13, 06:54 AM
WhatYaGot
WhatYaGot's Avatar
GL!
If it would go down to the floor it would be the master cylinder. I'm thinking maybe the booster check valve is going bad and loosing vacuum over time when parked. Anyone else agree?
Old 09-29-13, 10:41 AM
drewster12
drewster12's Avatar
I had the same issues and replaced by brake booster. Occasionally I still have the issue. I don't know, but it could be due to hot brake pads? I know when I brake a lot and then park, key off the car, come back, I have the stiff brake issue.
Old 09-29-13, 10:19 PM
topspeed55
topspeed55's Avatar
Most definitely a leak somewhere. Check the hose that goes from the booster to the intake manifold, search for visible cracks on the hose as well as the check valve. I'd probably replace the hose and valve first and if that doesn't solve it then unfortunately you may be looking at a leaking booster. Doubt it's the master cylinder problem as that usually causes the brake pedal to drop to the floor.
Old 10-16-13, 08:30 AM
WhatYaGot
WhatYaGot's Avatar
Any idea on how to replace the booster check valve? I heard it's easy to do and also looks like it's easy to access.
guxu
RX - 4th Gen (2016-2022)
19
06-03-21 04:23 PM
Ken167
09-01-18 02:39 PM
stnick007
Suspension and Brakes
03-02-18 06:03 PM
en11871
04-17-10 05:32 PM
Bane
06-13-05 01:06 PM
Quick Reply: Stiff Brake Pedal When Parked More Than 8 Hrs.
