ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   IS - 2nd Gen (2006-2013) (https://www.clublexus.com/forums/is-2nd-gen-2006-2013-163/)
-   -   06 IS250 won't start. (https://www.clublexus.com/forums/is-2nd-gen-2006-2013/709491-06-is250-wont-start.html)
jay90011 Sep 13, 2013 07:25 PM
Hey guys,
Need your help. So my car started up like normal when I left work. When I got home I turned off the car and went inside the house to change. When I went back to start the car it will not start. Everything turns on even the push button light turns green but while pressing the brake pedal the car won't crank. I do hear the fuel pump but no crank. Could it be that the fuel pump went bad? I checked the fuses and they all look good. I disconnected the battery for 10 minutes and hooked everything up and nothing. I checked the battery and it is good to. Battery is only six months old. I also tried to give it a jump with a friend and nothing.
Hopefully someone who has had this issue can direct me in the right direction.
Thanks
jay90011 Sep 13, 2013 07:30 PM
Forgot to add the car just hit 100,000 miles last week. All maintenance is up to date as well.
shadowman Sep 13, 2013 09:49 PM
Maybe bad ignition coil/starter ?
Did you try turning on your headlights to see if battery still had some charge left?
Any CEL or VCS lights?
vinsanity2 Sep 13, 2013 09:59 PM
a few things to look at:
1. shift to N and then back to P.. sometimes it may not be fully engaged.
2. starter could be a culprit, if you can possibly tap the starter while someone tries to crank, thats one way of testing, but it may be difficult to reach because its under the driver side exhaust manifold.
3. any signs of corrosion on battery terminals?
The problem symptoms table in the TIS says to follow these steps after checking battery has good voltage for no crank.
1. Check push-start function initialization
2. Immobilizer System
3. ECM power source circuit
4. VC output circuit
5. Cranking holding function circuit
6. Starter
jay90011 Sep 14, 2013 12:16 AM
Yea, headlights turn on fine. and no CEL or VCS lights.
jay90011 Sep 14, 2013 12:24 AM
- I tried this and still wont start.
- I will have to try this tomorrow and see if this could be the culprit.
- No Corrosion on any of the battery terminals
- i don't think this maybe the problem because the push button turns green when i press on the brake pedal.
- My car still recognizes my key fog and locks/unlocks the doors fine.
- Not sure where this circuit is at. if you can tell me where it is i can hopefully check to see if this maybe the problem.
- Not sure where this circuit is as well.
6. Starter
If you can help direct me where the circuits are would be great. I will also check the starter tomorrow.
vinsanity2 Sep 14, 2013 08:19 AM
sure I'll pm ya the pdf files
jay90011 Sep 14, 2013 01:45 PM
Awesome, thanks for the pdf's. So my issue is with my starter it is bad.
I also tapped on the starter and the car started. But after turning it on several times it finally gave out again.
Just ordered a new starter right now so my car will be on jack stands till it comes in.
1FlexedLex Sep 14, 2013 04:07 PM
change the battery on the key fob
cokoaT Sep 14, 2013 07:49 PM
it sounds like ur starter with no crank....push start usally doesnt have a problem with only 100 miles
vinsanity2 Sep 14, 2013 07:51 PM
Np, glad ya found the problem
jay90011 Sep 23, 2013 10:51 AM
Just thought i would share. So this weekend i received my rebuilt starter that i bought on ebay.
Comes out that it is 1/2 inch longer than the oem starter that was on the vehicle. When i attempted to install the rebuilt starter it would not fit. The space to install the starter is so cramped up small that it would not budge to align it with the opening. I ended up buying a rebuilt kit from napa and replaced just the solenoid after researching the common issues with starters.
I changed out the solenoid from the original starter and greased up the internals as well with axle grease. I installed the Oem starter again and went in to start the car and the car turned over and started.
Now the only question i have is, Do all starters sound the same when starting a vehicle? I ask because even though the car starts on the first second of pushing the push button it sounds much different than the original solenoid.
