AFS light on after coilover swap
Hey guys, so after swapping my Megan EZ coilovers with a member here for the stock suspension on my IS350, the "AFS OFF" light is blinking & it won't go away. I believe it is what controls our headlights to turn right or left based on the direction of the steering wheel. Any idea how to get the light to go off? Also since it happened, my driver side fog light does not come on anymore
I ran into the same issue when I lowered my car. I just loosened the bolt on the rear sensor and slid the bolt up. In your case the bolt should probably be moved down, the factory position of mine was in the middle so you might try that. You might also have to readjust each headlight after you move it.
Like Panda08 said, it's probably just coincidence that your fog light burnt out at the same time.
