I did the TPMS canister mod ,
set the tires to 2nd set,
can is at 50psi , tried lower psi also .
getting a low pressure light still...
Did I miss something?
This is the 2nd set , main are in the stock wheels, and yeah I programmed them myself,
Since its reading low pressure and not check system I'm assuming that part was done correctly...
Sounds like its working - I had to seal the TPMS canister twice to finally get it to stop leaking. It was fine around 20 PSI but leaked after 35
Originally Posted by panda08
I didn't think you could program tpms sensors yourself?
You can, with the toyota techstream software & cable
Yup, you can register the tpms yourself with tech stream, and I wanted to turn of my drl's.....
the can is holding air , can't figure or why it's still reading low pressure ,
Ok , lol I think I figured out the problem .
When I first put air in the can the cap blew off along with the filling and a sensor, turns out 2 sensors blew out , jus found it on the floor in the garage, damn damn damn
...how many people really have their own tech stream/ cable...
