Rack and Pinion Problems and Repair: What to look for?
Hi guys a few weeks ago my steering and the car in general began to feel weird and wobbly. The car is a 2007 IS250 with 68,000 miles.
About a week after that my steering began to feel slightly loose and then started to make a whirring noise whenever it was turned to the left or right.
I took it to a mechanic who said I needed to take the carry to a rack and pinion specialist. Indeed, when I went under the car with the mechanic the sound was coming from the rack and pinion.
I will be taking it to a specialist tomorrow for repairs. However, I was just wondering if you guys could share your experiences with me so that I can know what to look for tomorrow so I know the repair guy is doing the repairs correctly. What exactly has most likely gone wrong with the rack and pinion?
UPDATE*** The rack and pinion was repaired or so the shop said and put on the car. The noise is gone BUT the steering is very stiff you have to fight to turn it. Also the P/S power steering light is on. The shop said this is because the steering needs to be re calibrated. My question is after replacing a rack and pinion is this stiffness normal? The car cannot be driven because of the stiffness.
Thanks in advance for your replies.
Does anyone know anything about reprogramming the rack and pinion.
The guy that repaired it forgot to disconnect the battery and now the electronic module needs to be reprogrammed. A guy will be coming to reprogram it today but I wanted to get any knowledge possible about the reprogramming process beforehand.
Thank you B16da9, so that's the TIS techstream software?
Do you know if any other software can work? Why I ask is because I have been calling around trying to find someone or somewhere that has the software and so far no luck. Other people are saying that other software can do it but I am kind of skeptical you know.
Ok so having called the world and his wife trying to get a better understanding as to why the steering is stiff and the p/s power steering light is on. My question is will a recalibration solve the stiffness of the steering? I would feel more comfortable if someone who is experienced does the recalibration. i found a shop but it is far away from the garage where the car is located. the car cannot be driven due to the stiffness of the steering so i would have to tow it to the location for a lot of money. to make matters worse the shop with the techstream software is saying that they think the racked and pinion was not repaired correctly and if they diagnose and recalbrate and its still stiff i would have to pay. so just trying to get a better understanding.
