IS250 Carbon Build up CSP
#181
^^^ You do not need a letter to get this work done as long as you have problem as far as I know. Well I didn't have a letter or real shaking in the car and mentioned the carbon build up just as one of my worries and they are doing the work as soon as the parts come in.
This warranty covers 9 yrs/unlimited miles for the carbon build up problem. so you are covered.
Ive been reading through this thread for the past few days, I picked up my IS250 2 weeks ago. I have an 2006 with 57000 miles. Im encroaching on 72 months (I think that is the monthly limit, but I could be wrong) would I be covered? And I am also curious if the previous owner had it done.
#185
#186
Keeping my fingers crossed that they can replicate it...
#187
I just got a letter that it's extended for 9 years unlimited miles for my car. I think the notice said 2006 through 2010 (but not all 2010). If you just bought it, you may not be on the Lexus mailing list. Maybe if you register your car on lexus.com Owner's site, there's a notice? Otherwise, dealer should be able to tell you from your VIN.
#188
I bought my 07 IS250 cpo and still haven't received the letter. In addition, I used Chevron Techron fuel additive once and WOT a few times a week (both stopped since I heard of this extended coverage) and the problem hasn't noticeably come back.
#189
Like I stated earlier, I bought my car used, from an auction. It was a recovered theft and was missing only the nav unit, no issues with the car what so ever! The car has a reconstructed title and its my 9th reconstruct (most have been floods or recovered thefts). With the reconstruct I know dealerships fix "recalls" is the top engine clean and recall or warranty work? Now after reading though pretty much every thread, this one got my attention as it applies to me. I registered my car on Lexus's site (like I was instructed to do by a fellow member on this thread) and got all the service records. I attached a screen shot of my computer and the records. Does this mean I already had a top engine clean done and I dont have to lose sleep over it?!
#192
This is what I'm worried about. Called the dealer to make an appointment for them to check it. If they can't replicate the condition (which happens maybe once a week), and they don't see any misfire codes in the ECU, they say I'm out of luck. Somehow, they are distinguishing between "intermittent" (which is covered) vs. "infrequent" which is "normal." I asked if they could scope the engine to see if there's carbon buildup, but I'd have to pay the hourly rate for them to do it.
L-SB-0068-11
#193
Officially, the CSP only covers the misfire and rough idle issue. unofficially, Lexus knows the consumption is related and is not trying to screw those people over. It's just much more complicated when the complaint is oil consumption......and in the end...guess what......the proof they'll use to authorize it will be the same duplicated misfire recording.
So if you have legitimately bad oil consumption......make life easier on you and your dealership...just take the car there and complain about the oil consumption AND the car intermittently shakes at idle. if you're burning a good amount of oil, you will have some serious carbon buildup in there too. you're not doing anything wrong by saying that, just making the process of getting your consumption problem fixed a lot easier.
#195
Keeping it Real
it is related. worn cylinder wall, scratched cylinder walls, and just worn out rings will cause excessive blow-by. the blow-by leads to excessive carbon buildup as well as oil consumption. also, the carbon become hard and crystallized and scratch the cylinders. this is why about half of the oil consumption cars end up getting new short blocks.
Jeff
