Money saved and ready to order, but please help with specs!
Ok, FINALLY I'm ready to drop $$ on wheels...been researching for too long, and asked too many places for quotes, and read too many threads...
I've decided finally to go with XXR 527 and Hankook V12 and have some questions regarding specs and looks I'm going with 18x8.75..........but would I be able to pull off a +20 offset? I'm dropped on H&R (is250 awd)........or be safe and go with +35? For tires, I know 225/40 is probably ideal for 9inch, but this is 0.25 narrower than 9....so should I stick to this or go with something narrower like 215/40R18? As for lugs...I'm thinking Muteki SR48.........my car is silver, and probably going with chrome or flat black for the 527, what colour lugs would look good in this combination? I'm thinking either gunmetal to stay close to wheel and car colours, or red for some contrast? any input would be highly appreciated! Thanks! |
18 x 8.75 +35, 225/40-18, no comment on the lug nuts.
no way to run +20 without fender mods?
i have about 1.5-2 finger gaps left on the stock 17 |
^ id go with projectdna's reccomendations.
Originally Posted by reyoasian
(Post 7466651)
Thanks!
How about a stagger setup 18x8.75 +35 front with 215/40 or 225/40 18x9.75 +35 rear with 245/35 or 255/35 |
(Post 7466795)
Thanks!
How about a stagger setup 18x8.75 +35 front with 215/40 or 225/40 18x9.75 +35 rear with 245/35 or 255/35 *square: same size/specs |
(Post 7466651)
Remember to follow the guideline in this thread if running staggered on AWD
https://www.clublexus.com/forums/is-...-part-uno.html |
Originally Posted by pchan0
(Post 7466912)
Go with the +20 so you don't regret later on and run spacers, I know I did.
https://www.clublexus.com/forums/is-...of-my-car.html
This guy is on +20 all around lowered on h&r, but hes rwd with 9.75 in the rear. he needed fender mods. I say go with projectdna's suggestion |
Originally Posted by suxeLSI003
(Post 7466924)
Originally Posted by projectdna
(Post 7466927)
yes, and don't forget rolled fenders, too. :rolleyes:
Originally Posted by tedward88
(Post 7466930)
(Post 7467106)
Rolling fenders really a bad idea?
however, it will give you the maximum amount of fender-tire clearance to run wider, lower-offset wheels. Thanks...that is VERY USEFUL! Is like almost exact same situation as me lol. I guess the +35 will do...but should I stagger.???? |
(Post 7467113)
it's permanent, and short of replacing all your fender sheetmetal, irreversible.
however, it will give you the maximum amount of fender-tire clearance to run wider, lower-offset wheels. again, go w/ a square set-up. keep it simple. 8.75 is pretty wide anyways! |
if you didnt buy the wheels yet I recommend the Bavaria BC10's over the xxrs :)
http://i1210.photobucket.com/albums/...-BC10-CHRM.jpg |
