is350 problems
Old Jul 10, 2012 | 09:17 AM
jorgevr4's Avatar
jorgevr4
Default is350 problems
Hi guys just bought my 07 is350 with 105,000 miles on it. Is there any problems that I should worry about with this model or year.. I did some research before I bought the car and all the reviews are good. And Also is there any scheduled maintence that I should with this type of miles.
Old Jul 10, 2012 | 09:18 AM
Shervin350's Avatar
Shervin350
nothing to worry about change sparks if they havent been changed, just keep up with regular maintenance
Old Jul 10, 2012 | 09:22 AM
My0gr81's Avatar
My0gr81
there are some isolated report of spontaneous implosion if racing with IS250 at the light. j/k
Old Jul 10, 2012 | 09:26 AM
jorgevr4's Avatar
jorgevr4
Alright nice Thanks. This forums been a big help.
Old Jul 10, 2012 | 09:27 AM
jorgevr4's Avatar
jorgevr4
lmao!!! I hope not
Old Jul 10, 2012 | 09:42 AM
RDIS250AWD's Avatar
RDIS250AWD
LOLOLOLOLOL I'm somewhat offended since I have a 250 but I don't race anyways.
Old Jul 10, 2012 | 10:14 AM
bob4256's Avatar
bob4256
You shouldnt have any problems. Just keep up with the regular maintenance and you should be fine
Old Jul 10, 2012 | 11:25 AM
mixa86's Avatar
mixa86
whats the point, civcs are getting faster )))
just kidding 250's !
Old Jul 10, 2012 | 04:30 PM
Gville350's Avatar
Gville350
Sad part is...they are faster. Boo!
Enjoy the 350...they're bulletproof.
Old Jul 10, 2012 | 05:54 PM
anthrax144's Avatar
anthrax144
As was mentioned, change the spark plugs and also the radiator fluid if they haven't already been replaced - sparks plugs were due at 60k and radiator fluid at 100k miles. Inspect the serpentine belt for wear/cracks and replace if needed. Brake pads are as needed. The rest of the maintenance is just standard oil and filters.
Old Jul 10, 2012 | 06:58 PM
slimjimtel's Avatar
slimjimtel
Check the rear calipers. There was a recall to replace or regreased the guide pins. IF your pins are seized, you will notice your rear brakes wearing differently from the inside pad to the outside.
https://www.clublexus.com/forums/att...9lb-0001-w.pdf
Old Jul 11, 2012 | 04:20 AM
jorgevr4's Avatar
jorgevr4
I figured the spark plugs. Do You guys suggest the stock sparkplugs. And is there a specfic radiator fluid that I have to use. I have always driven a Honda so they always have upgrades for everything lol but it was very slow compared to this car.
Old Jul 11, 2012 | 05:11 AM
4wheelin's Avatar
4wheelin
Stock plugs are the way to go ...i'm guessing that the fluid change should be whatever came in the car.
Old Jul 11, 2012 | 02:22 PM
oblivionis's Avatar
oblivionis
I believe a brake fluid change is recommended. I also changed the rear diff fluid.
Old Jul 11, 2012 | 04:01 PM
Kurtz's Avatar
Kurtz
Brake fluid is every 30k (so 30,60, 90, 120, etc), same time you change air/cabin filters
Plugs are every 60k... coolant is at 100k.
Hartaj24
Apr 22, 2020 08:55 PM
scruthirds
Nov 16, 2017 03:39 PM
monacoDK
Apr 10, 2015 10:35 AM
MnGs3xx
Oct 7, 2013 01:29 PM
r4z0r3ck
Jul 23, 2006 07:55 PM
