DIY transmission fluid change question for IS250 - Page 4 - ClubLexus - Lexus Forum Discussion
Thread Tools Search this Thread
Old 01-20-18, 03:21 PM   #46
2013FSport
2013FSport's Avatar
As for new or any fluid expanding the existing rubber O-rings or seals that is not true of anything but those transmission rebuilds in a can. Those have things like either or/or other products with binders that reduce their evaporation period. Once added, these products **magically induce swelling** of rubber like O-rings and and ya, some leaks are reduced. And when the additive evaporates, the trans leaks like a sieve.
Rubber, neoprene, and other pliable materials do use fluid to keep them soft. Heat on the other hand and repeated heat cycling makes these components harden. Once they become rigid and are no longer pliable, they no longer apply pressure to the Teflon sealing rings they were expanding and the trans can experience internal leaks. Internal leaks create a loss of clamp force pressure at pistons acting on bands, clutch pack drums, and other components and here is where the trans begins to slip under load and burn those clutches and bands. As the fluid burns it fills with debris and soon after the valve body and solenoids act up as that debris is impairing their function. This is the beginning of the end for the trans.
Fresh fluid is nearly always a good thing throughout the life of trans. As in, after that initial 60 to 90K mi, a 25k fluid swap is GOOD THING! Do IT!
2013FSport is offline   Reply With Quote
The Following User Says Thank You to 2013FSport For This Useful Post:
primavera (01-20-18)
Old 02-10-18, 12:58 AM   #47
bryceis250
bryceis250's Avatar
ive been using mine to deliver Chinese food, not really by choice. the Camry is like a pair of ice skates, so with the weather we been having i use the IS because it is amazing in the snow. the gas mileage isn't the best of course. im looking for something else , but for right now im using her.
bryceis250 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
DIY 15 Quart ATF Transmission Fluid FLUSH 2004 Lexus LS430 Done at Home handogg LS - 3rd Gen (2001-2006) 11 10-30-17 10:40 PM
ES350 DIY transmission fluid change dreyfus ES - 5th Gen (2007-2012) 24 09-03-17 12:10 AM
IS350 differential fluid change DIY Janizary IS - 2nd Gen (2006-2013) 112 08-06-17 01:32 PM
New 01-03 Transmission fluid exchange w/pics 911LE LS - 3rd Gen (2001-2006) 4 07-30-17 08:19 AM
Changing Transmission Fluid in a 5 spd - Easier than using the drain plug DshngDaryl SC430 - 2nd Gen (2001-2010) 6 08-30-16 07:50 PM
Tags
250 , change , fill , fluid , fluids , flush , is250 , lexus , lifetime , replace , tranny , transmision , transmission , trasmission , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2017 Internet Brands, Inc. All Rights Reserved We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
